I blieve that for BE3600 the wifi driver is not compatible with Luci. You cannot do everying in luci.
Correct. Also, apologies for the duplicate: Slate 7 - GL-BE3600 channel analysis not working and causes luci logout
@alzhao also broken on Beryl AX firmware v4.8 beta
It should only work on op24 firmware, right?
I'm not sure, but if that's true I hope it can be fixed and added eventually. It's a very useful feature to have even if you "trust" the router to automatically choose the best band.
So why doesn't it work for me?
- enable WiFi feature
- change browser, or enable "In Private" mode to avoid being affected by browser extensions
- reset the router firmware
