Slate 7 slower speed than Beryl AX
I just bought new Slate 7 router to replace my Beryl AX, and when using my laptop (which has WiFi 6) speed of copying file from other computer in the network dropped from 90+ MB/s to 60 MB/s. The setup is identical for both routers, both connect at 1200mbps to the laptop (link speed), that other computer is connected to the router via ethernet, but Slate 7 provides lower actual data transfer rate.
Ho do I fix this?
Are you talking about USB read/write speed?
Is your BE3600 using the standard power adapter?
What format is your USB device in?
No, it's actually network speed. My setup is following: server <-> router <-> laptop. Server is connected to the router via 1 Gbit Ethernet, laptop - via WiFi. In both cases WiFi connection is 5 Ghz, 102.11ax mode, 1200Mbps. Laptop has WiFi 6 adapter. Router is connected to 100W PD adapter.
When I use Beryl AX as a router, and copy large file (10GB or so) from the server to the laptop, file is copied at about 90-100 MB/s, though when I swap the router to Slate 7 (having same settings as Beryl AX), copying speed drops to 60 MB/s.
What I also noticed is following. When I use iperf3 to check speed, on Slate 7 I get quite low numbers:
~> iperf3 -c 192.168.8.1 -R
Reverse mode, remote host 192.168.8.1 is sending
[ ID] Interval           Transfer     Bitrate
[  5]   0.00-1.00   sec  20.8 MBytes   174 Mbits/sec
[  5]   1.00-2.00   sec  27.6 MBytes   232 Mbits/sec
[  5]   2.00-3.01   sec  29.1 MBytes   243 Mbits/sec
[  5]   3.01-4.00   sec  30.2 MBytes   254 Mbits/sec
I can get slightly faster speeds if I run it in parallel (pasting only SUM values here for brevity):
~> iperf3 -c 192.168.8.1 -R -P 4
[SUM]   0.00-1.00   sec  36.0 MBytes   301 Mbits/sec
[SUM]   1.00-2.00   sec  46.1 MBytes   387 Mbits/sec
[SUM]   2.00-3.01   sec  47.0 MBytes   393 Mbits/sec
[SUM]   3.01-4.01   sec  49.9 MBytes   418 Mbits/sec
Though with Beryl AX I get faster speeds even with one connection:
[  5]   0.00-1.00   sec  58.6 MBytes   491 Mbits/sec
[  5]   1.00-2.00   sec  73.2 MBytes   614 Mbits/sec
[  5]   2.00-3.01   sec  75.6 MBytes   632 Mbits/sec
[  5]   3.01-4.00   sec  75.4 MBytes   635 Mbits/sec
Can you connect to BE3600 to test again?
During the test, collect the following information when the laptop is connected to the router's WiFi speed test:
  1. cat /etc/config/wireless
  2. wlanconfig wlan1 list //Execute this 5 times
  3. apstats -i wifi1 -r //Execute this 5 times
If it is convenient, you can also connect to MT3000 to test and collect information
Send the collected information to us for inspection
Also,What is the model of your laptop's Wi-Fi network card?
Sent output of mentioned commands to support@gl-inet.com with topic "Slate 7 slower speed than Beryl AX". During copying file for collecting these data speed was around 60-80 MB/s.
My WiFi adapter is "MediaTek Wi-Fi 6 MT7921 Wireless LAN Card" (Asus TUF Gaming A16 laptop).
Update from email communication:
The thing appeared to be that Slate 7 had "DE" as country code, and Beryl AX had "US", and power for different country codes is different. After I set Slate 7 country code to "US", file copy speed became 90-110 MB/s.
