Slate 7 Wireguard Client - Can't Resolve Remote LAN hosts using VPN DNS Settings
Have a brand new Slate 7 running 4.8.1 and testing it out as a travel router to vpn back to a home Wireguard Server (PIVPN/Pi5) that supports a windows domain and internal windows DNS server.
Wireguard profile connects fine and from windows/iOS/Android clients is also able to resolve remote LAN host names with no issue using connection specific suffix included in conf file.
When using the same profile on the Slate 7, the tunnel comes up, but automatic DNS settings do not forward any requests to the remote LAN DNS servers. (ex: 192.168.8.100 client on SLATE 7, SLATE 7 lan eth = 192.168.8.1, remote DNS server (192.168.10.200))
NS lookup and ping both work fine on the client side of the tunnel on my PC, but without manually specifying the DNS server in the adapter settings, it wont resolve hosts on the server side lan. This leads me to believe there is an issue with the traffic between the Slate interfaces when the VPN tunnel comes up.
I can NOT ping or use NS lookup from the Slate 7 UI, or SSH to the remote DNS server even though these functions work from the computer client using the router/tunnel.
It seems that the router itself is unable to forward or receive the DNS requests over the tunnel when it is up.
I have also tried going back to 4.7.3 - this tunnel method allows ping from the router over the tunnel to the DNS server, but lookup still fails, it also stops the clients from being able to use the DNS even with a manual DNS configuration.
Also, unsure if the firmware and wireguard client supports connection specific suffixes like the software clients? (Seems like this may have been changed in the 4.8.x firmware as it reads the suffix now, but unsure if it works.)
Any suggestions ?
Update:
Only seem to have gotten this to work by editing dnsmasq.conf and adding “server=/*.domain.lan/192.168.10.200”
The automatic use of the wireguard DNS settings does not seem to work at all.
Will ask R&D to check this.
Thanks for your feedback.
R&D has checked the cause and will fix this issue on future firmware versions.
Thanks for the follow up and looking into it. So it is confirmed that there is an issue there?
Yes, it will be fixed.
Is there any update on this issue? I have a slate 7, running firmware version 4.8.3 and am unable to get DNS lookups over my wireguard VPN. If I do an nslookup for the machine it fails, but if I add the ip for my VPN DNS, then it gets a result. How can I make this work?
In your case and topology, the WireGuard server end has a self-hosted DNS server (remote side), right? And the WireGuard client (slate7), LAN client send DNS queries to that DNS server, but the queries are not going through the WG tunnel?
If VPN mode is the "global", does nslookup return results?
how to I set the mode to global?
I also tried applying the same fix as above via ssh and managed to get it working. I’d prefer to do to properly rather than a custom hack though.
Thank you for the update, R&D team is evaluating a solution.
Please first use the temporary SSH workaround above.
