Slate AX and power strip with USB port
Hello!!
I’ve recently bought a GL-AXT1800 (Slate AX), it will arrive in a few days. I’m fairly new with these products, I’m afraid that this will not be the last question…
For space reasons, I would like to power the router using the USB-C port from a power strip with a USB port /2.4 A.
Could it be possible?
Thank you very much!! :grinning::grinning:
If you’re not plugging other things into the USB port on the Slate then you should be fine. Power usage is about 5W in normal conditions.
Hello!!
Thank you very much for your response!! :grinning::grinning:
I will not plug in anything, so for me it’s okay.
Best regards.
It should be pretty safe for 2.4A, as long as the power strip output is as advertised.
Hello!!
Thank you very much for posting the thread, I’ll read it.
Best regards!! :grinning::grinning:
