Slate AX and SD card performance
Is anyone using an SD card in Slate AX router? How is the Read and Write performance?
Thanks.
Not only depends on the router CPU/SD slot performance, but also the SD card performance.
I've got a SanDisk Max Endurance 128GB MicroSD card in my X3000 - I get 85-90MBps read and 30-35 MBps write, which is pretty much the rated speed of the SD card. I expect that faster specs on a card would yield faster results, but I wanted the longer lifespan.
Thats pretty good. Thanks!
Since you work for GLiNet I will ask you a simple question. What is the Max Read and Write Speeds in the TF/SD card Slot on Slate AX? And please don't be coy with your answer.
Thanks.
Samba, SD card -> LAN PC:
R: Max. about 81MB/s
W: Max. about 41MB/s
Looks like our test SD card Samsung Evo Plus U1 64GB is not better than SanDisk Max Endurance. So the most importance is based on the SD card performance.
What is the limitation of routers Read and Write speeds on Slate AX?
Thanks.
