Hi, My Slate AX is randomly crashing/rebooting. I've tried both the released firmware and the 4.6 beta. Same result.
I've been emailing support since May 4th, but they never respond to my emails. I posted in the Beta thread as well, but support did not reply to my post.
I've reset the router and configured it again, same result.
Latest logs are attached.
[[log removed]]
If anyone can help me resolve the issue, it would be greatly appreciated.
Check your forum registered email, we don't have any record in our ticket system. I suggest that you send the email again.
Checked your log. You use repeater and wifi channle 149, which could be a problem of wifi crashing when using router purchased from the EU. This may due to wrong wifi configuration. So doing a firmware reset should fix this issue.
In that case there is no CN version of it, I guess.
Is there anything connected with the crash; so maybe always the same procedure or something like this?
