Slate AX Crashing with 5GHz Client WiFi Enabled
I have looked at the following threads and tried all the options:
httpx://forum.gl-inet.com/t/gl-atx1800-crashes-when-connecting-to-home-wifi/25455/3 (not allowed to have more than 2 links in a post)
I’ve upgraded tried WiFi firmware versions 2.5, 2.6, 2.7. I’ve tried upgrading the Slate AX to 4.1 and the 4.2 beta versions. The only way I can keep it from constantly crashing is to disable the 5GHz client WiFi.
I have a crash log. Is there somewhere I can provide it to have someone look at it?
Can you share your crash log? you can export it in SYSTEM->Log
Paste is here:
Can you provide models of upstream hotspots? We need to do some tests
Most recently recreated the issue on Amplifi HD.
Bump. Any word on this? I’m about to throw this thing away.
Had similar issue with bad connector/power supply.
