LED configuration on luci is not persistent (tested on firmware version 4.1.0 and 4.2.0-beta3)
I customize a led behavior (white_led on ovpnclient transmit/recieve, for example), i click “Save & Apply” and the led starts blinking on vpn traffic, ok.
The problem is when i restart the router the behavior is lost, despite the rule kept on luci’s led configuration
You need to disable glinet’s LED manager with the following command
/etc/init.d/gl_led stop
/etc/init.d/gl_led disable
Where do you even enter that command?
Worked perfectly. Thanks a lot!
Log into the router via SSH to run the commands.
