Slate AX (GL-AXT1800) reset after reboot
When reboot device, it return router to factory settings, then I must setup from start again, WHY ?
Firmware is up to date.
Current Firmware
  • Version4.4.5
  • Firmware Typerelease1
  • Compile Time2023-08-11 16:06:15(UTC+08:00)
Are you using luci or just standard interface?
Hi I’m using standard, but have been in Luci to look.
Reload the firmware via uboot. This has solved the issue for me on occasion.
Upgraded to
Version: 4.4.6 release1
from
Version: 4.4.5 release1
This file is for local upgrade in web Admin Panel. (How?)
DOWNLOAD
Date Compiled: 2023-09-08 09:23:58 (UTC+02:00)
