Slate AX Missing 6Ghz Band
Hello all!
I just setup a new Slate AX Wifi 6 router that's updated to the latest firmware (4.7.0), and the 6Ghz band seems to be missing from the wireless settings in the router's admin panel.
The 2.4Ghz (both main and guest) and the 5Ghz (both main and guest) are there and seem to be working, but there's no settings for 6Ghz. I also poked around in the LUCI admin panel and it's the same there. Is there something that I need to add to get the 6Ghz band to appear in the panel?
Thanks for any help!
Wi-Fi on 6 GHz isn't supported.
The "Wi-Fi 6" is about the standard (which is "version 6") not about the frequencies.
