when doing opkg list-upgradable I get a lot of available updates.
In Luci there is only oui-httpd package available, why the difference?
Also when I installed the available packages in opkg the router stopped responding and I had to do a reset to get it working again, I beleive it was netifd that caused it.
I want to have the latest software available, is opkg update not recommended / supported?
alzhao
July 6, 2022, 10:43am
#2
What is your firmware version now? What did you install?
Today I installed the version with compile date 06-28 after being advised by your college to try and solve the app issue, I have not updated this one with opkg yet.
with the original firmware (06-03) I used a script that updates all upgradable packages, some packages installed correctly and then the router froze, likely when installing netifd. I had to do the 10s reset to get it back.
below is output from fresh installed 06-28 firmware:
root@slateax:~# opkg update; opkg list-upgradable
Downloading https://fw.gl-inet.com/releases/v21.02-SNAPSHOT/kmod-4.0/arm_cortex-a7/ip60xx/Packages.gz
Updated list of available packages in /var/opkg-lists/glinet_core
Downloading https://fw.gl-inet.com/releases/v21.02-SNAPSHOT/packages-4.0/arm_cortex-a7/glinet/Packages.gz
Updated list of available packages in /var/opkg-lists/glinet_gli_pub
Downloading https://downloads.openwrt.org/releases/21.02-SNAPSHOT/packages/arm_cortex-a7/base/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_base
Downloading https://downloads.openwrt.org/releases/21.02-SNAPSHOT/packages/arm_cortex-a7/luci/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_luci
Downloading https://downloads.openwrt.org/releases/21.02-SNAPSHOT/packages/arm_cortex-a7/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_packages
Downloading https://downloads.openwrt.org/releases/21.02-SNAPSHOT/packages/arm_cortex-a7/routing/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_routing
Downloading https://downloads.openwrt.org/releases/21.02-SNAPSHOT/packages/arm_cortex-a7/telephony/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_telephony
Updating database.
Database update completed.
terminfo - 6.2-1 - 6.2-3
libuci-lua - 2020-10-06-52bbc99f-5 - 2021-04-14-4b3db117-5
iwinfo - 2021-06-09-c0414642-2.1 - 2022-04-26-dc6847eb-1
ntfs-3g-utils - 2017.3.23-1-fuseint - 2017.3.23-6-fuseint
luci-app-opkg - git-21.079.58548-3bcbcbf - git-22.154.41894-1cf976c
iw - 5.9-1 - 5.9-8fab0c9e-3
libuci20130104 - 2020-10-06-52bbc99f-5 - 2021-04-14-4b3db117-5
rpcd - 2021-11-04-d11ffe93-1 - 2022-02-19-8d26a1ba-1
busybox - 1.33.1-7 - 1.33.2-2
libiwinfo-lua - 2021-06-09-c0414642-2.1 - 2022-04-26-dc6847eb-1
luci-mod-system - git-21.271.74796-7c943a1 - git-22.130.00635-21f99bd
openssl-util - 1.1.1k-1 - 1.1.1o-1
libustream-wolfssl20201210 - 2020-12-10-68d09243-1 - 2022-01-16-868fd881-1
luci-theme-bootstrap - git-21.283.63931-588e24f - git-22.084.39047-f1d687e
libusb-1.0-0 - 1.0.22-2 - 1.0.24-4
netifd - 2021-10-20-c61a1d43-1 - 2021-10-30-8f82742c-1
oui-httpd - git-2022.165.41286-967e048-1 - git-2022.179.30118-9d879c1-1
luci-mod-status - git-21.265.39600-b5464a3 - git-22.046.85784-0ac2542
libgpg-error - 1.42-1 - 1.42-2
lua-cjson - 2.1.0-1 - 2.1.0-2
firewall - 2021-03-23-61db17ed-1 - 2021-03-23-61db17ed-1.1
luci-app-firewall - git-21.243.76516-19c66ef - git-22.089.67741-3856d50
uci - 2020-10-06-52bbc99f-5 - 2021-04-14-4b3db117-5
rpcd-mod-file - 2021-11-04-d11ffe93-1 - 2022-02-19-8d26a1ba-1
nginx-ssl - 1.17.7-2 - 1.19.6-2
smstools3 - 3.1.21-2 - 3.1.21-4
libiwinfo-data - 2021-06-09-c0414642-2.1 - 2022-04-26-dc6847eb-1
luci-proto-ppp - git-21.158.38888-88b9d84 - git-21.163.64918-6c6559a
luci-base - git-21.284.67084-e4d24f0 - git-22.167.28411-ee8170b
wireguard-tools - 1.0.20191226-1 - 1.0.20210223-2
libopenssl1.1 - 1.1.1k-1 - 1.1.1o-1
luci-proto-ipv6 - git-21.148.48881-79947af - git-21.148.49484-14511e5
ntfs-3g - 2017.3.23-1-fuseint - 2017.3.23-6-fuseint
libopenssl-conf - 1.1.1k-1 - 1.1.1o-1
libncurses6 - 6.2-1 - 6.2-3
libiwinfo20210430 - 2021-06-09-c0414642-2.1 - 2022-04-26-dc6847eb-1
zlib - 1.2.11-3 - 1.2.11-4
mwan3 - 2.8.15-2 - 2.10.13-1
luci-lib-jsonc - git-19.317.29469-8da8f38 - git-22.097.61937-bc85ba5
rpcd-mod-iwinfo - 2021-11-04-d11ffe93-1 - 2022-02-19-8d26a1ba-1
luci-mod-network - git-21.285.33716-9aaebdf - git-22.046.85061-dd54dce
wireless-regdb - 2021.04.21-1 - 2021.08.28-1
Collected errors:
* pkg_hash_check_unresolved: cannot find dependency libstdcpp6 for nginx-util
* pkg_hash_fetch_best_installation_candidate: Packages for nginx-util found, but incompatible with the architectures configured
* pkg_hash_check_unresolved: cannot find dependency libstdcpp6 for nginx-ssl-util
* pkg_hash_fetch_best_installation_candidate: Packages for nginx-ssl-util found, but incompatible with the architectures configured
This does not look right with double entries, firmware 2022-06-28 7:21:42(UTC+08:00)
alzhao
July 11, 2022, 2:38am
#7
It is display bug that when there is new version of a software package.
