I’d like to try cake sqm with slate ax.
The plugin page cant find the above related files to install, maybe add the link to those files in your next build, thanks
I still think you should have cake sqm built into your GL UI
edit 24/05/2022:
doing this ssh command updates the package list and i was able to install cake sqm
