My ISP is AT&T Fiber. My Modem is the Nokia BGW320-505. My home router is the Flint GL-AXT1800 Router. My travel router is the Slate AX1800. I set up port forwarding on my modem. I set up the WireGuard VPN server with the Flint Router. I tried setting up the WireGuard VPN client with the Slate router, but it just says "The client is starting, please wait…" and the light stays yellow. Can someone help me resolve this issue?
[Interface]
Address = 10.0.0.2/24
PrivateKey =
DNS = 64.6.64.6
MTU = 1420
[Peer]
AllowedIPs = 0.0.0.0/0, ::/0
Endpoint = yd4c7c6.glddns.com:51820
PersistentKeepalive = 25
PublicKey = sbTotrcM7/B3iXySmLzN+5fmcdtaVNhL0T+Zs7WAtic=
Fri Jul 5 15:10:30 2024 daemon.notice netifd: wgclient (5885): * Rule 'lan_in_conn_mark_restore'
Fri Jul 5 15:10:30 2024 daemon.notice netifd: wgclient (5885): * Rule 'out_conn_mark_restore'
Fri Jul 5 15:10:30 2024 daemon.notice netifd: wgclient (5885): * Zone 'lan'
Fri Jul 5 15:10:30 2024 daemon.notice netifd: wgclient (5885): * Zone 'wan'
Fri Jul 5 15:10:30 2024 daemon.notice netifd: wgclient (5885): * Zone 'guest'
Fri Jul 5 15:10:30 2024 daemon.notice netifd: wgclient (5885): * Zone 'wgclient'
Fri Jul 5 15:10:30 2024 daemon.notice netifd: wgclient (5885): * Set tcp_ecn to off
Fri Jul 5 15:10:30 2024 daemon.notice netifd: wgclient (5885): * Set tcp_syncookies to on
Fri Jul 5 15:10:30 2024 daemon.notice netifd: wgclient (5885): * Set tcp_window_scaling to on
Fri Jul 5 15:10:30 2024 daemon.notice netifd: wgclient (5885): * Running script '/etc/firewall.nat6'
Fri Jul 5 15:10:30 2024 daemon.notice netifd: wgclient (5885): * Running script '/etc/firewall.swap_wan_in_conn_mark.sh'
Fri Jul 5 15:10:30 2024 daemon.notice netifd: wgclient (5885): * Running script '/etc/firewall.vpn_server_policy.sh'
Fri Jul 5 15:10:30 2024 daemon.notice netifd: wgclient (5885): * Running script '/var/etc/gls2s.include'
Fri Jul 5 15:10:30 2024 daemon.notice netifd: wgclient (5885): ! Skipping due to path error: No such file or directory
Fri Jul 5 15:10:30 2024 daemon.notice netifd: wgclient (5885): * Running script '/usr/bin/gl_block.sh'
Fri Jul 5 15:10:30 2024 daemon.notice netifd: wgclient (5885): Failed to parse json data: unexpected character
Fri Jul 5 15:10:30 2024 daemon.notice netifd: wgclient (5885): uci: Entry not found
Fri Jul 5 15:10:31 2024 daemon.notice netifd: Interface 'wgclient' is now down
Fri Jul 5 15:10:31 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Fri Jul 5 15:10:31 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
