I got a warning at this page
Router time differs from your browser
when i press sync, it syncs me to shanghai location, but I’m not there
What location/timezone are you in?
Is the timezone correct? i.e. same as Shanghai?
I chose asia/kuala lumpur +8
I am at kuala lumpur
asia/shanghai is also +8
I see. I think that is the reason. It only detect the timezone, not the real location.
This seems to be “normal” across my GL.iNet routers, not just the Slate AX. I set the timezone to America/Toronto, but it shows America/New York after syncing, which is in the same timezone.
