Hello. I have a slate configured as a repeater bridge. it's worked fine for 2 months. this week it changed. clients connected directly are fine. clients connected through a wifi hotspot are blocked from browsing and updates. Pings to host names still work.Any ideas?
Hi, could you help us confirm the following?
What is your exact Slate model and full firmware version? The latter can be found in Admin Panel - System - Upgrade.
Is the Slate connected to the upstream network via Repeater, with Ethernet-connected devices working normally, but devices connected to the Slate's Wi-Fi unable to browse or download updates?
Please run these commands on an affected Wi-Fi device and share the outputs:
# Windows (Command Prompt) nslookup google.com tracert 8.8.8.8 curl -vvv google.com # macOS / Linux nslookup google.com traceroute 8.8.8.8 curl -vvv google.comIf all three work normally, please describe what happens when browsing or downloading updates and include a screenshot of the error or symptom.
