I’ve been testing the speed on AT&T. I have three hotspots, a Unite Explore, a Netgear Nighthawk M1, and the Gl.iNet MiFi. These all have their own SIM, post pay AT&T, Unlimited Plus plan, stream saver turned off. All SIMS have their own 22GB allotment. The Mifi is not under deprioritization. The Unite Explore has 55Gb used with 15 days left, the Nighthawk has 155Gb with 15 days left, and I’d have to log into the AT&T backroom to tell you what the Mifi is, but I haven’t been using it as much, so I doubt it’s too much over 10Gb. I could be wrong, I’ll check later. So the two Netgears are falling under deprioritization on this tower, but it’s hardly ever congested. You can’t tell if/when it is.
The Mimo antenna has made things faster before, but today we are having a small snowstorm. About 3 inches, and it’s coming down at a decent rate. I’m less than a mile from the tower, and it’s usually 700mhz or 1900mhz. Both seem to go through the trees just fine.
Test One – Unite Explore USB Tether into AR300M
Test Two – Unite Explore USB Tether into AR300M
Test Three – Unite Explore, Unite Explore USB Tether into AR300M with Mimo antenna
Test One – Nighthawk M1, over ethernet WAN into AR300M, No MIMO ext antenna
Test Two – Nighthawk M1, over ethernet WAN into AR300M, No MIMO ext antenna
Test Three – Nighthawk M1, over ethernet WAN into AR300M, No MIMO ext antenna
Test One – MiFi over ethernet Wan into AR300M, external 5dbi oar antenna Only one, lead was too short for other sma adapter, longer cable on the way for diversity antenna. Right now internal LTE antenna is hooked to diversity. Not sure what the impact of that is, but with only an internal antenna, and no diversity plugged in, the speed tests are similar. I think they were more 9Mbs to 13Mbs down, and the same for uploads. So I think the antenna is a weak spot for the MiFi. I have no idea why the uploads are consistently higher than the downloads since the antenna swap.
Test Two – MiFi over ethernet Wan into AR300M, external 5dbi oar antenna
Test Three – MiFi over ethernet Wan into AR300M, external 5dbi oar antenna
All of these tests for all hotspots were run in the order posted, in about 30~45 minutes, mid afternoon on a Saturday, in a slight snowstorm, all next to the same window towards the same tower. The MiFi seems to hamstring the AR300M’s throughput if I put the Mifi in with one of the other hotspots for load balancing. 4G LTE is also very volatile, so it’s difficult to get consistent charts. So I didn’t do but a few tests with the Mifi load balanced, and I didn’t save that information. I plan on revisiting it with the second antenna soon.
