Hi all, I am having low speed while using wireguard vpn with flint 2. I am using Surfshark wireguard. I tested the speeds using speedtest app. As you can see in the pictures, the first test is with wireguard vpn setup in the router. The second is with the vpn turned off. The third is using Surfshark app for the iPhone.
There is something going on and I don’t know what. Can you help me to have speed similar to the app?
Thank you.
current firmware on Flint2?
The latest one. 4.7.7
I don't have this issue - I'm getting the speeds i'm paying for. What surfshark server are you connecting to on the router? on your mobile it usually goes to the best/fastest, same as the desktop app. so I would test it against setting the server location statically.
I am trying to connect to India, Mumbai server. There are only two Indian servers and I don’t think there would be issue with the fastest. I managed to bring the speed to 71mbps by trying different MTU. It’s around 1400. I don’t know whether this is the solution or need to change anything else.
Still not resolved. Now, again the speed is around 25Mbps on flint 2. Got slat 7, with same vpn wireguard server getting 72 mbps.
Anyone have any clue?
EDIT: Found the solution. Not to use speedtest. It’s inaccurate. Tried using it with different site, giving the normal speeds of around 73 Mbps.
I will mark this as solution.
