I need some help to figure out and improve Wireguard speeds. I have 2 GL-MT1300 (Beryl) units, 1 serving as Wireguard VPN Server at home and 2nd unit serving as mobile VPN Wireguard client (mainly at vacation home). I have 100 MBPS up and down at both locations. I’m only getting 2 MBPS up and down over VPN.
Following is output of trace rt from client to server (glddns).
1 4 ms 2 ms 1 ms console.gl-inet.com [192.168.8.1]
2 65 ms 59 ms 56 ms 10.0.0.1
3 191 ms 131 ms 66 ms pool-72-83-xxx-yyy.washdc.fios.verizon.net [72.83.xxx.yyy]
I had these configured as OpenVPN and I was getting much better, 8Mbps up and 5Mbps down, but not good enough for video call.
I primarily use work laptop which has corporate Cisco AnyConnect. When connected using Openvpn, everything works. When connected using Wireguard, Outlook doesn’t work. I suspect my Wireguard handshake is not proper/optimized and as such Cisco Anyconnect Tunnel has issues working within Wireguard tunnel. Or, there’s leakage.
I’m not very savvy with this. Please advise how can i troubleshoot or which commands I can run.
Thanks.
