I need to forward SMS via ntfy - PUT/POST to your phone | F-Droid - Free and Open Source Android App Repository
I don’t have IMAP unfortunately (Tutanota), so I must use workarounds. Unfortunately forwarding as SMS is EXTREMELY expensive
P.S: Can I submit this as feature request too?
admon
May 10, 2024, 5:50pm
2
You could get yourself another mail provider just for forwarding those SMSes to mail.
Or you can script yourself a way to use the SMS files and send them via whatever service you like. All incoming SMS are stored as plain text within the filesystem, so it’s easy to work with them.
admon:
Which one? Not google/apple/outlook as they are actively scanning my mails.
Can you help me with this?
Tool is extremely easy to use
curl -d "SMS text" ntfy.sh/mytopic
admon
May 10, 2024, 6:12pm
4
I always recommend mailbox.org since I love them, and they are nearly as secure as Tuta (I use both), but they are paid-only.
I can try to script something, but it will need a few hours/days, depending on my mood.
Interesting
Never heard about them. I will try and write back
admon:
hours/days
It is not urgent at all
For now I will try mailbox.org if they have IMAP. If so, that’s ok. 1 Euro is not a lot
UPD: @admon mailbox.org seems to fix my issue. Thanks!
