Not sure if anyone try the snapshot build for GL-MT3000 Beryl AX dated Aug-10 & Aug-11. I found that if it is in router mode, it works fine but once I change it to AP mode, the router is just keep rebooting every 3 - 4 minutes. Can someone from Glinet engineering check if it is the case. No problem for the build before that. Thanks.
Have you found crash logs in the MT3000 log?
In AP mode, how many WiFi/Wiring clients connected to MT3000?
The latest snapshot Aug-13, is this issue reproduce?
I do not have enough time to login and get any logs. Also, it is not related to number of connected clients. I only have a few at home and most of them only connect occasionally. BTW, I still only se the one dated Aug-11 on the web site GL.iNet download center
Just update using openwrt-mt3000-4.8.1-0814-1755114191.tar and stable after upgrade.
