Socks5 mullvad
I want to enable SOCKS5 proxy for all my internet traffic using the VPN. Is this possible? there seems to be very limited vpn options within the router just pick your VPN provider and the country and thats all. Theres no options for multi hop, SOCKS5 or other settings you would find inside the mullvad app.
No, out-of-the-box those configurations are not available. A router uses a way easier mechanism than the app. You can use OpenVPN or Wireguard. That's all so far.
Other things might require manual try and error.
@randomuser1 Do you have specific need for an explicit proxy? There is probably a better way to do this on the router through VPN policy etc. What are you trying to achieve that needs a proxy specifically?
