My Brume 2 is the DHCP server for my network. It routes between my ISPs modem/router, and my Wifi network (an eero hub interconnected with another 3 such nodes - eero operates only at layer 2). I use it only for:
routing / DHCP
basic firewall, with 80/443 forwarded to an internal NGINX reverse proxy
DNS with AdguardHome
ddns-scripts (to namecheap)
I will also implement a wireguard-based VPN sometime in the future.
Yes, I had tried this - it did not solve my problem. After I implemented the solution described above, I have re-enabled it, and that has caused no problem..
Sorry, I know this is an ancient post but any chance you have another suggestion?
I wish this resolved my issue. I was so hopeful, but no. I'm back to having mdns issues with my Beryl. For some reason none of the .local domains resolve and I really can't figure out why. Frustrating.
