I don’t think ping really matters in this issue.
Your purpose is still use wireguard right? We are develop a UI to configure wireguard easily. Modifying files is difficult.
Maybe we can add luci-app-wireguard as well so that you can configure it.
Hey, sorry for not being around. Just to update the issue - I am apparently dumb and did not check everything. It was not the router at fault. It was my ISP throttling UDP connections, it just happened to be right after using a router with newer firmware.
Thank you for your time and effort to help me, and sorry that it was something as stupid as this.
P.S. - would you recommend using the ath10k-ct drivers or the regular ath10k?
Cheers!
Thanks for letting me know.
We tried CT firmware before but performance not so good. Didn’t try recently.
Hi. what kind of wifi speeds do you get now? (without wireguard)… I need to know if wifi is stable now before ordering (planning to use vanilla openwrt).
Thanks
Just some info from me: you can just flash vanilla openwrt on B1300 and it works great.
Thanks for reply. So now wifi performance is fixed in current openwrt?
I installed OpenWRT 18.06.1 today and while the signal graphs in the web UI look really bad (first SSID is around 50%, second one 0%) my client devices seem to work great so far - in fact signal strength seems to be quite a bit better than before…
UPDATE: I did not actually try the guest SSID because in Android it looked fine. However, I cannot even connect to it. The other SSID still works fine…
Thanks for the reply. I was actually wondering about throughput… ie if you transfer files or download large stuff over wifi, what kind of speeds do you get?
Is it realistic to expect 400mbps+ over wifi from the B1300?
