I used the gl.inet supplies image builder for a MT300N and built new firmware. My problem is after building using the gl.inet image builder, I am seeing errors when trying to use packages.
opkg update
Downloading http://downloads.openwrt.org/chaos_calmer/15.05/ramips/mt7620/packages/base/Packages.gz.
Updated list of available packages in /var/opkg-lists/chaos_calmer_base.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05/ramips/mt7620/packages/base/Packages.sig.
Signature check passed.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05/ramips/mt7620/packages/luci/Packages.gz.
Updated list of available packages in /var/opkg-lists/chaos_calmer_luci.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05/ramips/mt7620/packages/luci/Packages.sig.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05/ramips/mt7620/packages/management/Packages.gz.
Updated list of available packages in /var/opkg-lists/chaos_calmer_management.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05/ramips/mt7620/packages/management/Packages.sig.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05/ramips/mt7620/packages/oldpackages/Packages.gz.
wget: server returned error: HTTP/1.1 404 Not Found
Downloading http://downloads.openwrt.org/chaos_calmer/15.05/ramips/mt7620/packages/oldpackages/Packages.sig.
Signature check failed.
Remove wrong Signature file.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05/ramips/mt7620/packages/packages/Packages.gz.
Updated list of available packages in /var/opkg-lists/chaos_calmer_packages.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05/ramips/mt7620/packages/packages/Packages.sig.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05/ramips/mt7620/packages/routing/Packages.gz.
Updated list of available packages in /var/opkg-lists/chaos_calmer_routing.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05/ramips/mt7620/packages/routing/Packages.sig.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05/ramips/mt7620/packages/telephony/Packages.gz.
Updated list of available packages in /var/opkg-lists/chaos_calmer_telephony.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05/ramips/mt7620/packages/telephony/Packages.sig.
Collected errors:
- opkg_download: Failed to download http://downloads.openwrt.org/chaos_calmer/15.05/ramips/mt7620/packages/oldpackages/Packages.gz, wget returned 1.
- opkg_download: Failed to download http://downloads.openwrt.org/chaos_calmer/15.05/ramips/mt7620/packages/oldpackages/Packages.sig, wget returned 1.
I was still able to install a package but seeing those errors above. However, note that the following is the contents of the repo file which is all gl.inet locations which is what was used when building. Sp, why is this happening?
src/gz chaos_calmer_base http://www.gl-inet.com/openwrt/ramips/2.20/packages/base
src/gz chaos_calmer_luci http://www.gl-inet.com/openwrt/ramips/2.20/packages/luci
src/gz chaos_calmer_management http://www.gl-inet.com/openwrt/ramips/2.20/packages/management
src/gz chaos_calmer_packages http://www.gl-inet.com/openwrt/ramips/2.20/packages/packages
src/gz chaos_calmer_routing http://www.gl-inet.com/openwrt/ramips/2.20/packages/routing
src/gz chaos_calmer_telephony http://www.gl-inet.com/openwrt/ramips/2.20/packages/telephony
src/gz chaos_calmer_oldpackages http://www.gl-inet.com/openwrt/ramips/2.20/packages/oldpackages
src/gz chaos_calmer_node http://www.gl-inet.com/openwrt/ramips/2.20/packages/node
