I took a pre-activated SIM card and popped it into the GL-MiFi EC25-AF modem (which covers several Verizon bands). The SIM had already been activated in another device so it worked.
I am having intermittent success accessing the internet but occasionally instead of showing the signal strength, I’m seeing a “SIM card not registered” message displayed. Sometimes it goes away and I am usually able to access the internet while I see the message; however, occasionally the internet does not work.
I’m wondering if you have any tips on fixing this.
I should add that the internet is generally working even when the " SIM card not registered" is displayed and AT+CREG? displays +CREG: 0,3. Seeing speeds of about 10-15Mbps Down and 5-10Mbps up.
I asked FAE of QUECTEL, his feedback is whether the module needs to register the network according to AT+CREG?, AT+CGREG? and the AT+CEREG?
I just judged AT+CREG?, Therefore, this is a BUG in the code
