Just got my AR750S over the weekend. Yesterday it was working perfectly. I was able to connect to my cellular hotspot over wifi and share to multiple laptops. I unplugged it at the end of the workday and brought it home. I then turned it back on at home and successfully connected to my home wifi router.
This morning I started up my cellular hotspot, plugged in the router, gave it a couple of minutes, then tried connecting with one of the laptops I was using yesterday. I can connect to the interface, but the AR750S can’t see my hotspot anymore. In fact, it can’t see ANY SSID.
I tried the 3 second reset. I tried the 10 second reset. I tried installing the 3.003 firmware back to the AR750S via the web interface.
Nothing is working. The radios clearly work, as I can connect over wifi to the interface, but I cannot get it to find ANY SSID on a scan.
