mbw
All -
For added security, we use preshared keys (PSK) for each of our WireGuard clients
PresharedKey =XYZ
This directive is not honoured in the client configuration for WireGuard via the client configuration.
Would you please add support for this or advise how to use a custom configuration with that directive included?
It’s been discussed and there is an open bug task on it. A workaround is listed on the tracking page:
mbw
3
@lostdog Thank you. I will take a look.
qld654
4
Can anyone describe the workaround here?
alzhao
5
It is old. There are preshared key support now.
