Some setting are not saved between uses. Especially noticeable to me are local cursor option and video quality. What's odd is that sometimes it seems like they do save.
Do other people experience the same thing?
Didn't receive feedback of this issue. Could you try again and share the log files to us?
Some configurations are stored on the frontend, which means that changing browsers or clearing the cache may result in the loss of these settings. We are gradually migrating them to be saved on the backend.
That must be it. I often start with a cleared browser. Other than minor things like that it's been a great product!
Hmmm..i change the scroll settings to 0 over and over, but I jump between two Macs...done it on both, yet it always get reset to 5. Is that from jumping between them?
on 1.4.0 beta2? it shoud be a bug
You are correct, I was on the previous stable release and it didn't hold. Updated to the 1.4.0 beta 2 and it's holding now! Thank you!
