Hi, is there anywhere could get some detail about gl-mifi-portal-test-v3.bin ?
This firmware has added a portal crack program, which can deal with captive portal even though VPN or DNS over TLS is enabled.
If you use portal to access the internet, you can try it. Any feedback is welcome.
Thanks for reply,
I installed the portal version. It seems based on gl-mifi-3.009.bin.
