Speed up boot time
I’m using MT300A router and use it as a portable shadowsocks hotspot. It takes about 45 to 55 seconds from power on to ready to work.
So, my question is, if I only need:
  1. shadowsocks client with udp relay support
  2. iPhone usb tethering
  3. wifi client
what components can be removed to speed up?
I have tried to disable shadowsocks server/lighthttpd/uhttpd/usb storage/kmondvideo, but can’t get sooner than 45 seconds. I’m aiming for less than 20s, is that possible?
Here is my boot log:
Blockquote
[ 0.000000] Linux version 4.4.92 (kyson@gl-inet) (gcc version 5.4.0 (LEDE GCC 5.4.0 r3560-79f57e422d) ) #0 Tue Oct 17 17:46:20 2017
[ 0.000000] Board has DDR2
[ 0.000000] Analog PMU set to hw control
[ 0.000000] Digital PMU set to hw control
[ 0.000000] SoC Type: MediaTek MT7620A ver:2 eco:6
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU0 revision is: 00019650 (MIPS 24KEc)
[ 0.000000] MIPS: machine is GL-MT300A
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 08000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] On node 0 totalpages: 32768
[ 0.000000] free_area_init_node: node 0, pgdat 803bc4b0, node_mem_map 81000000
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 32768 pages, LIFO batch:7
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=132768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyS0,115200 rootfstype=squashfs,jffs2
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Writing ErrCtl register=00067f30
[ 0.000000] Readback ErrCtl register=00067f30
[ 0.000000] Memory: 125540K/131072K available (3059K kernel code, 145K rwdata, 728K rodata, 156K init, 208K bss, 5532K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:256
[ 0.000000] CPU Clock: 580MHz
[ 0.000000] clocksource: systick: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 583261500 ns
[ 0.000000] systick: enable autosleep mode
[ 0.000000] systick: running - mult: 214748, shift: 32
[ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6590553264 ns
[ 0.000012] sched_clock: 32 bits at 290MHz, resolution 3ns, wraps every 7405115902ns
[ 0.007577] Calibrating delay loop… 385.84 BogoMIPS (lpj=1929216)
[ 0.070073] pid_max: default: 32768 minimum: 301
[ 0.074706] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.081077] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.094749] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.104303] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.110365] pinctrl core: initialized pinctrl subsystem
[ 0.116787] NET: Registered protocol family 16
[ 0.140886] rt2880_gpio 10000600.gpio: registering 24 gpios
[ 0.146337] rt2880_gpio 10000600.gpio: registering 24 irq handlers
[ 0.152486] rt2880_gpio 10000638.gpio: registering 16 gpios
[ 0.157888] rt2880_gpio 10000638.gpio: registering 16 irq handlers
[ 0.164012] rt2880_gpio 10000660.gpio: registering 32 gpios
[ 0.169413] rt2880_gpio 10000660.gpio: registering 32 irq handlers
[ 0.175533] rt2880_gpio 10000688.gpio: registering 1 gpios
[ 0.180845] rt2880_gpio 10000688.gpio: registering 1 irq handlers
[ 0.188504] clocksource: Switched to clocksource systick
[ 0.195192] NET: Registered protocol family 2
[ 0.200459] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.207185] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.213411] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.219641] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.225267] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.231708] NET: Registered protocol family 1
[ 0.235926] PCI: CLS 0 bytes, default 32
[ 0.240462] rt-timer 10000100.timer: maximum frequency is 1220Hz
[ 0.247266] Crashlog allocated RAM at address 0x3f00000
[ 0.269235] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.274857] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.287293] io scheduler noop registered
[ 0.291105] io scheduler deadline registered (default)
[ 0.296283] ralink-usb-phy usbphy: invalid resource
[ 0.301646] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.311458] console [ttyS0] disabled
[ 0.314907] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 20, base_baud = 2500000) is a Palmchip BK-3103
[ 0.324579] console [ttyS0] enabled
[ 0.331615] bootconsole [early0] disabled
[ 0.346493] spi spi0.0: force spi mode3
[ 0.351014] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.355858] 5 ofpart partitions found on MTD device spi0.0
[ 0.361502] Creating 5 MTD partitions on “spi0.0”:
[ 0.366401] 0x000000000000-0x000000030000 : “u-boot”
[ 0.373312] 0x000000030000-0x000000040000 : “u-boot-env”
[ 0.380673] 0x000000040000-0x000000050000 : “factory”
[ 0.387627] 0x000000050000-0x000000fd0000 : “firmware”
[ 1.700713] 2 uimage-fw partitions found on MTD device firmware
[ 1.706778] 0x000000050000-0x000000192da9 : “kernel”
[ 1.713485] 0x000000192da9-0x000000fd0000 : “rootfs”
[ 1.720456] mtd: device 5 (rootfs) set to be root filesystem
[ 1.726382] 1 squashfs-split partitions found on MTD device rootfs
[ 1.732764] 0x0000009c4000-0x000000fd0000 : “rootfs_data”
[ 1.740189] 0x000000ff0000-0x000001000000 : “art”
[ 1.747913] rt2880-pinmux pinctrl: pin io40 already requested by pinctrl; cannot claim for 10100000.ethernet
[ 1.758034] rt2880-pinmux pinctrl: pin-40 (10100000.ethernet) status -22
[ 1.764893] rt2880-pinmux pinctrl: could not request pin 40 (io40) from group ephy on device rt2880-pinmux
[ 1.774850] mtk_soc_eth 10100000.ethernet: Error applying setting, reverse things back
[ 1.785769] gsw: setting port4 to ephy mode
[ 1.790123] mtk_soc_eth 10100000.ethernet eth0 (uninitialized): port 0 link up (100Mbps/Full duplex)
[ 1.799659] mtk_soc_eth 10100000.ethernet: loaded mt7620 driver
[ 1.806509] mtk_soc_eth 10100000.ethernet eth0: mediatek frame engine at 0xb0100000, irq 5
[ 1.815734] rt2880_wdt 10000120.watchdog: Initialized
[ 1.822561] NET: Registered protocol family 10
[ 1.830808] NET: Registered protocol family 17
[ 1.835443] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.848384] 8021q: 802.1Q VLAN Support v1.8
[ 1.854384] hctosys: unable to open rtc device (rtc0)
[ 1.873214] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[ 1.881336] Freeing unused kernel memory: 156K
[ 4.325151] init: Console is alive
[ 4.328945] init: - watchdog -
[ 8.850036] kmodloader: loading kernel modules from /etc/modules-boot.d/
[ 8.947624] usbcore: registered new interface driver usbfs
[ 8.953387] usbcore: registered new interface driver hub
[ 8.958966] usbcore: registered new device driver usb
[ 8.970608] exFAT: Version 1.2.9
[ 9.014055] SCSI subsystem initialized
[ 9.025197] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 9.033909] ehci-platform: EHCI generic platform driver
[ 9.049688] phy phy-usbphy.0: remote usb device wakeup disabled
[ 9.055736] phy phy-usbphy.0: UTMI 16bit 30MHz
[ 9.060321] ehci-platform 101c0000.ehci: EHCI Host Controller
[ 9.066217] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
[ 9.074436] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
[ 9.086999] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[ 9.094553] hub 1-0:1.0: USB hub found
[ 9.098811] hub 1-0:1.0: 1 port detected
[ 9.106458] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 9.114771] ohci-platform: OHCI generic platform driver
[ 9.120469] ohci-platform 101c1000.ohci: Generic Platform OHCI controller
[ 9.127483] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
[ 9.135658] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
[ 9.165881] hub 2-0:1.0: USB hub found
[ 9.170164] hub 2-0:1.0: 1 port detected
[ 9.177250] uhci_hcd: USB Universal Host Controller Interface driver
[ 9.197979] MTK MSDC device init.
[ 9.215584] mtk-sd: MediaTek MT6575 MSDC Driver
[ 9.223621] sdhci: Secure Digital Host Controller Interface driver
[ 9.230007] sdhci: Copyright(c) Pierre Ossman
[ 9.235935] sdhci-pltfm: SDHCI platform and OF driver helper
[ 9.246370] usbcore: registered new interface driver usb-storage
[ 9.256224] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 9.267807] init: - preinit -
[ 10.797930] 8021q: adding VLAN 0 to HW filter on device eth0
[ 12.606929] jffs2: notice: (409) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 12.627620] mount_root: switching to jffs2 overlay
[ 12.650029] urandom-seed: Seeding with /etc/urandom.seed
[ 12.801569] procd: - early -
[ 12.804729] procd: - watchdog -
[ 13.636033] procd: - watchdog -
[ 13.639527] procd: - ubus -
[ 13.988324] random: ubusd: uninitialized urandom read (4 bytes read, 25 bits of entropy available)
[ 14.003227] random: ubusd: uninitialized urandom read (4 bytes read, 26 bits of entropy available)
[ 14.100962] random: ubusd: uninitialized urandom read (4 bytes read, 26 bits of entropy available)
[ 14.113925] random: ubusd: uninitialized urandom read (4 bytes read, 26 bits of entropy available)
[ 14.123211] random: ubusd: uninitialized urandom read (4 bytes read, 26 bits of entropy available)
[ 14.132601] random: ubusd: uninitialized urandom read (4 bytes read, 26 bits of entropy available)
[ 14.142566] random: ubusd: uninitialized urandom read (4 bytes read, 26 bits of entropy available)
[ 14.152204] procd: - init -
[ 15.282337] random: jshn: uninitialized urandom read (4 bytes read, 28 bits of entropy available)
[ 15.380989] kmodloader: loading kernel modules from /etc/modules.d/*
[ 15.659411] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[ 15.681999] Initializing XFRM netlink socket
[ 15.695329] NET: Registered protocol family 15
[ 15.701591] random: ubusd: uninitialized urandom read (4 bytes read, 28 bits of entropy available)
[ 15.714238] tun: Universal TUN/TAP device driver, 1.6
[ 15.719407] tun: (C) 1999-2004 Max Krasnyansky [email protected]
[ 15.727204] random: ubus: uninitialized urandom read (4 bytes read, 28 bits of entropy available)
[ 16.164599] l2tp_core: L2TP core driver, V2.0
[ 16.178949] l2tp_netlink: L2TP netlink interface
[ 16.205846] gre: GRE over IPv4 demultiplexor driver
[ 16.226098] ip_gre: GRE over IPv4 tunneling driver
[ 16.264189] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 16.300607] Netfilter messages via NETLINK v0.30.
[ 16.318353] ip_set: protocol 6
[ 16.758932] Loading modules backported from Linux version wt-2017-01-31-0-ge882dff19e7f
[ 16.767182] Backport generated by backports.git backports-20160324-13-g24da7d3c
[ 17.191863] i2c /dev entries driver
[ 17.303848] u32 classifier
[ 17.306623] input device check on
[ 17.310354] Actions configured
[ 17.339296] Mirror/redirect action on
[ 17.381109] nf_conntrack version 0.5.0 (1964 buckets, 7856 max)
[ 17.451962] fuse init (API version 7.23)
[ 17.502483] usbcore: registered new interface driver cdc_acm
[ 17.508272] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 17.554900] usbcore: registered new interface driver cdc_wdm
[ 17.579293] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 17.605300] usbcore: registered new interface driver ipheth
[ 17.834134] usbcore: registered new interface driver usbserial
[ 17.840195] usbcore: registered new interface driver usbserial_generic
[ 17.847033] usbserial: USB Serial support registered for generic
[ 17.998894] xt_time: kernel timezone is -0000
[ 18.008579] usbcore: registered new interface driver cdc_ether
[ 18.038003] usbcore: registered new interface driver cdc_ncm
[ 18.058754] usbcore: registered new interface driver cp210x
[ 18.064655] usbserial: USB Serial support registered for cp210x
[ 18.095218] usbcore: registered new interface driver huawei_cdc_ncm
[ 18.179167] PPP generic driver version 2.4.2
[ 18.193272] PPP MPPE Compression module registered
[ 18.214160] NET: Registered protocol family 24
[ 18.220943] PPTP driver version 0.8.5
[ 18.238867] usbcore: registered new interface driver qmi_wwan
[ 18.256553] usbcore: registered new interface driver rndis_host
[ 18.336376] rt2800_wmac 10180000.wmac: loaded eeprom from mtd device “factory”
[ 18.343851] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 6352, rev 0500 detected
[ 18.351769] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 7620 detected
[ 18.359523] ieee80211 phy0: Selected rate control algorithm ‘minstrel_ht’
[ 18.394943] usbcore: registered new interface driver sierra
[ 18.400749] usbserial: USB Serial support registered for Sierra USB modem
[ 18.435307] usbcore: registered new interface driver sierra_net
[ 18.462883] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 18.485691] usbcore: registered new interface driver option
[ 18.491500] usbserial: USB Serial support registered for GSM modem (1-port)
[ 18.526551] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 33.161364] 8021q: adding VLAN 0 to HW filter on device eth0
[ 33.173562] device eth0.1 entered promiscuous mode
[ 33.178470] device eth0 entered promiscuous mode
[ 33.193258] br-lan: port 1(eth0.1) entered forwarding state
[ 33.198993] br-lan: port 1(eth0.1) entered forwarding state
[ 35.192082] br-lan: port 1(eth0.1) entered forwarding state
[ 40.683237] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 40.711000] device wlan0 entered promiscuous mode
[ 44.091727] IPv6: ADDRCONF(NETDEV_UP): wlan-sta: link is not ready
[ 47.050378] wlan-sta: authenticate with some MAC
[ 47.079710] wlan-sta: send auth to some MAC (try 1/3)
[ 47.087309] wlan-sta: authenticated
[ 47.103976] wlan-sta: associate withsome MAC (try 1/3)
[ 47.116227] wlan-sta: RX AssocResp fromsome MAC (capab=0x411 status=0 aid=2)
[ 47.124676] wlan-sta: associated
[ 47.128241] IPv6: ADDRCONF(NETDEV_CHANGE): wlan-sta: link becomes ready
[ 47.175925] wlan-sta: Limiting TX power to 20 (20 - 0) dBm as advertised by 6e:ab:31:39:f5:3c
[ 47.804390] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 47.811097] br-lan: port 2(wlan0) entered forwarding state
[ 47.816814] br-lan: port 2(wlan0) entered forwarding state
[ 47.827365] wlan-sta: deauthenticating from 6e:ab:31:39:f5:3c by local choice (Reason: 3=DEAUTH_LEAVING)
[ 48.087620] br-lan: port 2(wlan0) entered disabled state
[ 48.814091] wlan-sta: authenticate with 6e:ab:31:39:f5:3c
[ 48.828360] wlan-sta: send auth to 6e:ab:31:39:f5:3c (try 1/3)
[ 48.835954] wlan-sta: authenticated
[ 48.843982] wlan-sta: associate with 6e:ab:31:39:f5:3c (try 1/3)
[ 48.851774] wlan-sta: RX AssocResp from 6e:ab:31:39:f5:3c (capab=0x411 status=0 aid=2)
[ 48.860241] wlan-sta: associated
[ 48.941302] wlan-sta: Limiting TX power to 20 (20 - 0) dBm as advertised by 6e:ab:31:39:f5:3c
[ 49.518670] br-lan: port 2(wlan0) entered forwarding state
[ 49.524402] br-lan: port 2(wlan0) entered forwarding state
[ 50.294694] br-lan: port 2(wlan0) entered forwarding state
[ 50.415806] random: nonblocking pool is initialized
It causes by flash’s erasesize, has fixed it next release, and fixed reserve setting when upgradeing.
Next release means 2.271? And what’s the approximate ETA?Looking forward to it.
It is v3.0, with a new ui.
When is v3 available for testing?:kissing_heart:
It will be available for testing in next week.
Is Ver 3.0 will be available for GL-B1300?
Not yet, only for mini router.
also try remove file system support, l2tp.
Anyway, the USB and wifi part takes a lot of time.
Is v3 test version available?
Not yet!!! It postponed by one week.
One week later :sunglasses:
Will be 1 more week i think because OpenWRT just finalized the new release, so they have been waiting for that :smiley:
Totally understand.
Just saying my eagerness.:grinning::grinning::grinning:
We are releasing beta version for AR750S this week and AR750S will be shipped from next week. But for old products still need time.
I have 95s wait time before tertf: br-lan registered step. did you ever find a fix? br-lan is ethernet bridge -- is there a setting to fix that?
more context
[   40.215564] kmodloader: done loading kernel modules from /etc/modules.d/*
[   40.228000] kmodloader: ["gl_system": "kernel_load"]
[  134.407742] tertf: br-lan registered, add it
[  134.451124] eth0: link up (1000Mbps/Full duplex)
This thread is pretty old, please continue in your new thread 2.5 minute boot time on GL-AR750 -- how to fix.
