yes, as @wcs2228 said, this program is not compiled for this router and it does not run.
So, today I’m at home and have a little time with my beryl (should be the same architecture as Opal … But since we’re installing via OpenWRT package manager, this should not be important).
- Open the Luci webfonend:
Login on the GL.iNet Frontend - On the left hand menu go to 'More settings - Advanced'
If there is no Link, click on the Button (Install), else click on the link. - Login at the Luci frontend. User ‘admin’, use the previous password.
- On the Top Menu go to
System - Softwareand on the first search field search fornetperf - Behind
speedtest-netperfclick on the buttonInstall - READ the dialogs!
At the end close the dialog with ‘Dismiss’ down right.
Now login via ssh and type speedtest-netperf.sh → a lot of information.
Since you have now also netperf installed, you can try other scripts. Like betterspeedtest.sh Link or write a whole own script with defined/desired output.
Edit: Just write a little nicer.
I just now have seen this message. Just pulled my opal back out to try what you said though.
Weird… I got netperf installed. the speedtest-netperf gives
root@GL-SFT1200:/etc/speedtest# ./speedtest-netperf.sh
2023-02-14 18:18:07 Starting speedtest for 60 seconds per transfer session.
Measure speed to netperf.bufferbloat.net (IPv4) while pinging gstatic.com.
Download and upload sessions are sequential, each with 5 simultaneous streams.
WARNING: netperf returned errors. Results may be inaccurate!
Download: 0.00 Mbps
Latency: [in msec, 1 pings, 0.00% packet loss]
Min: 58.838
10pct: 0.000
Median: 0.000
Avg: 58.838
90pct: 0.000
Max: 58.838
CPU Load: [in % busy (avg +/- std dev), 0 samples]
Overhead: [in % used of total CPU available]
netperf: 0.0
Upload: 0.00 Mbps
Min: 126.649
10pct: 0.000
Median: 0.000
Avg: 126.649
90pct: 0.000
Max: 126.649
netperf: 0.0
I downloaded betterspeedtest.sh and ran it, even adding a high -t (seconds) didn’t do nothing it seems… When I tried, it immediately gives a finished test result, even though I added more time and more connections…
root@GL-SFT1200:/etc/speedtest# ./betterspeedtest.sh -t 500 -n 10
2023-02-14 16:34:21 Testing against netperf.bufferbloat.net (ipv4) with 10 simultaneous sessions while pinging gstatic.com (500 seconds in each direction)
Download: 0.00 Mbps
Latency: (in msec, 1 pings, 0.00% packet loss)
Min: 237.391
10pct: 0.000
Median: 0.000
Avg: 237.391
90pct: 0.000
Max: 237.391
Upload: 0.00 Mbps
Min: 231.479
10pct: 0.000
Median: 0.000
Avg: 231.479
90pct: 0.000
Max: 231.479```
The error message means you download the wrong CPU platform binary on your router.
Weird cause I downloaded the netperf from the plugin section of the GL-Inet gui.
The server (netperf.bufferbloat.net) blocked your IP. I faced the same issue. Don’t test more than a few times a day.
