Just got this router,set it up and connected to it ,great speed results etc,within a few mins then lost internet connection and unless reboot it stays off
G
Has the latest firmware it says
Only Newbie maybe doing something wrong
Any help appreciated
Ive reset it and started again but still the same
First you need to see what's wrong with the signal
AT+QRSRP
You need to learn to figure it out yourself.
AT+QRSP?what am i looking for,cheers
First, I would take a router and go to a cell tower.And see how it works with a good signal
Ill try again tomorrow
First you need to go to the quectel forum and ask for a new firmware for the MODULE.Then you need to download the new firmware for the router itself.
Then you need to do a full reset without saving the settings.This is for starters
Why? It is part of the Spitz interface now.
I see the RSRP is poor and even only fair out in the garden ,in a built up area btw,thanks
Changed the APN settings to everywhere,fingers crossed its stayed connected now ,appreciate your replies
