I encounter a weird problem with my Spitz AX (GL-X3000) and would gladly get some help !
I used it as modem and router for several months without issue, but one week ago I suddenly lost connection through Ethernet interface.
The thing is, everything still work while connected to the spitz through Wi-Fi on the same computer. While searching to solve this issue, suddenly ethernet worked again without any particular reason.
Couple hours later, same problem, suddenly no Ethernet connection to the router.
I can access my NAS or other LAN Ethernet device on my network from my computer, but the router sees nothing and does not respond to ping through ethernet.
Things that I tried :
Though of DHCP issue so I first fixed IP on my computer
Tested all cables and Ethernet interface on computers (not the spitz's)
Tested router connection on another computer with a live debian distribution
Turned off AdGuard
Reset firmware to default and upgrade
Trying both Ethernet interface on the Spitz
No other DHCP server on the network
Version : OpenWrt 21.02-SNAPSHOT r15812+882-46b6ee7ffc
Kernel Version : 5.4.211
Firmware Type0413release2
Module Version : RM520NGLAAR01A07M4G
Attached log file.
Thanks you for your help !
[logread.tar|attachment](upload://pLbwGKbTwPif8JJo49mVjxjhWuZ.tar) (201.5 KB)
