Spitz AX (GL-X3000) Firmware Beta version 4.4.13 2024-09-17
Has anyone tried the beta firmware on the Spitz AX (GL-X3000) router?
THIS IS THE Release Notes
Overview
This version mainly fixes some known bugs and add a new feature.
Support Models
Puli AX (GL-XE3000), Spitz AX (GL-X3000)
Function Added
Added esim function.
Bug Fixes
  • Fixed the issue that devices in the disabled internet group cannot access the web page when relay networking is enabled, parental control is enabled, and schedule is added as disabled internet.
  • Fixed the issue that Modem dialing fails when QMI is selected as protocol, APN is set manually and PAP/CHAP is selected as authentication method.
  • Fixed the issue that when the uplink 5G wireless is modified to 20M 165 channel, the relay cannot scan the wireless network.
I've been running it for few weeks now or whenever it was released. Love it and have finally had a rock solid router along with RM520NGLAAR03A04M4G_01.202.01.202. They have replaced that beta with a new 4.7 beta but they never ported it to stable for some reason. Kind of difficult for someone to purchase an eSIM and activate it without firmware support for it. Jumping over to 4.7 seems a little premature at the moment since 4.4.13 was rock solid.
I am running 4.7 since yesterday. Sofar so good.
I have also been running this modem firmware @gainestr mentioned and have not seen any issues. I recently reset my router and started over with configs, but I am still running 4.4.12.
