I would like to use the Wifi LED to indicate 4G and 5G.
E.g. 2.4 GHz for 4G active and 5 GHz for 5G active.
Is this possible?
We don’t support this setting, sorry for that.
I tested ATT card, which using NSA mode, i.e. 4G+5G. At this case, both 4G and 5G LED will be on, still don’t know 4G or 5G is using.
I guess you could check the band in use when in NSA mode and that would tell you if your on 5G or 4G.
AT+QENG=“servingcell”
+QENG: “servingcell”,“NOCONN”
+QENG: “LTE”,“FDD”,310,410,AD9EC96,232,9820,30,3,3,4C16,-102,-13,-71,8,4,230,-
+QENG: “NR5G-NSA”,310,410,283,-104,2,-13,651360,77,6,1
I already tested it. With this AT command, can check the band in use, showing both LTE and 5GNR bands are using.
