Will this model work throughout North America ( Canada, USA and Mexico ) . This model is available out of Hong Kong. Canadian Cell phones work in all of the above, but I am curious about this 'plug'
Is there a different model or 'plug' for NA only?
This model is designated 5G NR. Is it an older model?
The Spitz uses a Quectel RM520N-GL, which is great for most of the world!
If you want to be extra careful, you can check your carrier bands to see if they are supported.
For instance, if you check out the Wikipedia page for the 5G NR list, you'll see that Rogers uses N66, N71, N41, N78, and N77. All of those bands are covered by the RM520N-GL.
REF:
