Spitz AX (GL-X3000)
Wanna purchase Spitz AX (GL-X3000)
Spitz AX (GL-X3000) has two SIM cards slots. They are used simultaneously? Or I can control which one to use?
It have 2 IMEI? Or one? Does it support “temp” (custom) IMEI?
I need to insert both of them? Or one will be enough?
Does it have repeater mode?
Does it support network storage?
Only one sim card can connect at a time, you select which one.
It has one IMEI, and yes you can change it.
One sim card is fine.
Yes it has repeater mode.
Yes it has network storage.
