Spitz AX SIM Card lock
The SIMcard is unlimited and works normal on my phone. I have no pin code limit as far as I know. How can I find that out?
How many digits is your pincode?
It is 4 digits
that is normal I think
I will try another SIM (not vodafone but Telekom) this evening and come back to you
Turn off the SIM pin. You could always disable the sim through your account website, if needed.
Eric
I have made a reset. Its done in a few minutes.
Then delete the PIN.
All is working fine again.
This is a bug in 4.4.6
If you currently want to use pincode, you can use 4.4.3
The latest fix firmware 4.4.8 will be released in a few days, you can also wait
https://dl.gl-inet.com/router/x3000/
