Spitz AX X 3000 Locking specific cell id or Operator
Hi everyone,
I would like to know how it will be possible to lock to a specific cell id or to a specific provider.
I use the spitz ax x3000 near the boarder Germany / Switzerland.
Swiss network in roaming is way more performant as the german, but since I am using a German SIM it is always trying to reconnect to a weak non roaming telekom signal.
I want to use permanently:
+COPS: 0,0,"Salt",13
in 5G mode.
The only way i found out to do so for most of the cases is, to block all other bands except LTE band 3 and 5G band 28 from the salt cell see below.
But nevertheless sometimes it connects to a very weak signal from a German telekom cell also with id3 and without a 5G Band connection.
LTE FDD
Band 3
ul_bandwidth 20M
dl_bandwidth 20M
RSRP -107 Befriedigend
RSSI -72 Sehr Gut
RSRQ -11 Befriedigend
SINR 11 Gut
ID 1C7A201
NR5G-NSA
Band 28
dl_bandwidth 10 M
RSRP -86 Sehr Gut
RSRQ -11 Sehr Gut
SINR 15 Sehr Gut
I also identified in cell mapper the respective cells:
i want to connect to just this one:
|eNB ID 16530 (Macro) - LTE
|MCC / MNC / Region|228 / 3 / 47007|
|Bands|3, 20|
|Cell Identifier Cell 2|4231682|
|System Subtype|LTE|
|PCI|106 (35/1)|
|EARFCN|1601|
|Maximum Signal (RSRP)|-70 dBm|
|Bandwidth*|20 MHz|
|Uplink Frequency|1750.1 MHz|
|Downlink Frequency|1845.1 MHz|
|Frequency Band|DCS (B3 FDD)|
and I want to block this one:
|eNB ID 154175 (Macro) - LTE
|MCC / MNC / Region|262 / 1 / 26551|
|Bands|1, 3, 8|
|Cell Identifier Cell 11|39468811|
|System Subtype|LTE|
|PCI|99 (33/0)|
|EARFCN|1444|
|Maximum Signal (RSRP)|-89 dBm|
|Direction|S (175°)|
|Max RSRQ|-2 dB|
|Max SNR|1 dB|
|Uplink Frequency|1734.4 MHz|
|Downlink Frequency|1829.4 MHz|
any ideas?
Thanks in advance!
Switch carriers?
