Spitz AX X3000 How to manually switch sim in auto mode
Ive had the X3000 running for a few weeks and its performing really well.
I have the auto switch mode enabled with dual sims, which also works fine.
Id like to know how to manually switch sim in this mode. Basically one network performs much better than the other, and I’d like to switch back to the primary sim before the alloted time that the “Checking Preferred Slot Status Scheduled” option dictates.
My current solution is to quickly turn off auto sim and then switch over , before re-enabling auto switch mode. This would be good enough for me if not for the fact that disabling auto switch loses the “Checking Preferred Slot Status Scheduled” setting, which is valuable.
Thanks
Thank you very much for your advice.
I’m checking it.
Hi - was there any progress on this?
I’d like to do more with SIM Auto Switch, and/or with bash scripts, but I can’t find any documentation of Auto Switch, or pointers to scripts to select one SIM or the other. Any pointers welcome :slight_smile:
