Spitz GL-X-750 tethering
Hi. I’ve been reading about this modem and it mentions tethering to a mobile phone to use the data from the phone. Does this mean that the signal is still received by the phone or the modem antennas? I want to connect external antennas to the modem to increase range in my boat.
Cheers.
Tethering means always using the phone as your connection - so no boost in signal here.
However you can insert a SIM in your X750 - in that case the router itself will act like a „phone“.
Understood, thanks for the help.
