Having issues getting my GL-X750 to connect reasonably quickly to Verizons network. After every reboot the modem take several minutes to possible hours to connect. I only say “possible hours” because I have not timed it just yet. Looking at the systems logs I see the same message repeated over and over again “modem hangup”, then randomly I end up with a successful connection.
One thing that I immediately notice is the order of the log messages Connect: 3g-modem_1_1_2 and 3g-modem_1_1_2: renamed from ppp0… See below.
This will be a failure
Mon Mar 16 00:32:26 2020 daemon.notice pppd[6308]: Connect: 3g-modem_1_1_2 <--> /dev/ttyUSB3
Mon Mar 16 00:32:26 2020 kern.info kernel: [14491.639478] 3g-modem_1_1_2: renamed from ppp0
Mon Mar 16 00:32:27 2020 daemon.notice pppd[6308]: Modem hangup
Mon Mar 16 00:32:27 2020 daemon.notice pppd[6308]: Connection terminated.
This will be a success
Mon Mar 16 00:32:32 2020 kern.info kernel: [14497.535158] 3g-modem_1_1_2: renamed from ppp0
Mon Mar 16 00:32:32 2020 daemon.notice pppd[6537]: Connect: 3g-modem_1_1_2 <--> /dev/ttyUSB3
Mon Mar 16 00:32:33 2020 daemon.warn pppd[6537]: Could not determine remote IP address: defaulting to 10.64.64.64
Here are the logs that show a successful connection along with many prior failures of the same type “modem hangup”.
Anyone have a thought as to what the issue might be?
Thanks in advance!
Mon Mar 16 00:29:06 2020 local2.info chat[31722]: timeout set to 10 seconds
Mon Mar 16 00:29:06 2020 local2.info chat[31722]: send (AT+CGDCONT=1,"IP","VZWINTERNET"^M)
Mon Mar 16 00:29:06 2020 local2.info chat[31722]: timeout set to 30 seconds
Mon Mar 16 00:29:06 2020 local2.info chat[31722]: expect (OK)
Mon Mar 16 00:29:06 2020 local2.info chat[31722]: ^M
Mon Mar 16 00:29:06 2020 local2.info chat[31722]: OK
Mon Mar 16 00:29:06 2020 local2.info chat[31722]: -- got it
Mon Mar 16 00:29:06 2020 local2.info chat[31722]: send (ATD*99***1#^M)
Mon Mar 16 00:29:07 2020 local2.info chat[31722]: expect (CONNECT)
Mon Mar 16 00:29:07 2020 local2.info chat[31722]: ^M
Mon Mar 16 00:29:07 2020 local2.info chat[31722]: CONNECT
Mon Mar 16 00:29:07 2020 local2.info chat[31722]: -- got it
Mon Mar 16 00:29:07 2020 local2.info chat[31722]: send ( ^M)
Mon Mar 16 00:29:07 2020 daemon.info pppd[31704]: Serial connection established.
Mon Mar 16 00:29:07 2020 daemon.info pppd[31704]: Using interface 3g-modem_1_1_2
Mon Mar 16 00:29:07 2020 daemon.notice pppd[31704]: Connect: 3g-modem_1_1_2 <--> /dev/ttyUSB3
Mon Mar 16 00:29:07 2020 kern.info kernel: [14292.440519] 3g-modem_1_1_2: renamed from ppp0
Mon Mar 16 00:29:08 2020 daemon.notice pppd[31704]: Modem hangup
Mon Mar 16 00:29:08 2020 daemon.notice pppd[31704]: Connection terminated.
Mon Mar 16 00:29:09 2020 daemon.info pppd[31704]: Exit.
Mon Mar 16 00:29:09 2020 daemon.notice netifd: Interface 'modem_1_1_2' is now down
Mon Mar 16 00:29:09 2020 daemon.notice netifd: Interface 'modem_1_1_2' is setting up now
Mon Mar 16 00:29:11 2020 daemon.notice netifd: modem_1_1_2 (31789): cat: can't open '/tmp/modem.1-1.2/signal': No such file or directory
Mon Mar 16 00:29:11 2020 daemon.notice pppd[31888]: pppd 2.4.7 started by root, uid 0
Mon Mar 16 00:29:12 2020 local2.info chat[31904]: abort on (BUSY)
Mon Mar 16 00:29:12 2020 local2.info chat[31904]: abort on (NO CARRIER)
Mon Mar 16 00:29:12 2020 local2.info chat[31904]: abort on (ERROR)
Mon Mar 16 00:29:12 2020 local2.info chat[31904]: report (CONNECT)
Mon Mar 16 00:29:12 2020 local2.info chat[31904]: timeout set to 10 seconds
Mon Mar 16 00:29:12 2020 local2.info chat[31904]: send (AT+CGDCONT=1,"IP","VZWINTERNET"^M)
Mon Mar 16 00:29:12 2020 local2.info chat[31904]: timeout set to 30 seconds
Mon Mar 16 00:29:12 2020 local2.info chat[31904]: expect (OK)
Mon Mar 16 00:29:12 2020 local2.info chat[31904]: ^M
Mon Mar 16 00:29:12 2020 local2.info chat[31904]: OK
Mon Mar 16 00:29:12 2020 local2.info chat[31904]: -- got it
Mon Mar 16 00:29:12 2020 local2.info chat[31904]: send (ATD*99***1#^M)
Mon Mar 16 00:29:13 2020 local2.info chat[31904]: expect (CONNECT)
Mon Mar 16 00:29:13 2020 local2.info chat[31904]: ^M
Mon Mar 16 00:29:13 2020 local2.info chat[31904]: CONNECT
Mon Mar 16 00:29:13 2020 local2.info chat[31904]: -- got it
Mon Mar 16 00:29:13 2020 local2.info chat[31904]: send ( ^M)
Mon Mar 16 00:29:13 2020 daemon.info pppd[31888]: Serial connection established.
Mon Mar 16 00:29:13 2020 daemon.info pppd[31888]: Using interface 3g-modem_1_1_2
Mon Mar 16 00:29:13 2020 daemon.notice pppd[31888]: Connect: 3g-modem_1_1_2 <--> /dev/ttyUSB3
Mon Mar 16 00:29:13 2020 kern.info kernel: [14298.359721] 3g-modem_1_1_2: renamed from ppp0
Mon Mar 16 00:29:14 2020 daemon.notice pppd[31888]: Modem hangup
Mon Mar 16 00:29:14 2020 daemon.notice pppd[31888]: Connection terminated.
Mon Mar 16 00:29:15 2020 daemon.info pppd[31888]: Exit.
######## Begin Repeated Messages #########
Mon Mar 16 00:29:21 2020 daemon.info pppd[32110]: Exit.
Mon Mar 16 00:29:27 2020 daemon.info pppd[32336]: Exit.
Mon Mar 16 00:29:32 2020 daemon.info pppd[32518]: Exit.
Mon Mar 16 00:29:41 2020 daemon.info pppd[347]: Exit.
Mon Mar 16 00:29:47 2020 daemon.info pppd[557]: Exit.
Mon Mar 16 00:29:53 2020 daemon.info pppd[789]: Exit.
Mon Mar 16 00:29:59 2020 daemon.info pppd[1020]: Exit.
Mon Mar 16 00:30:05 2020 daemon.info pppd[1193]: Exit.
Mon Mar 16 00:30:11 2020 daemon.info pppd[1438]: Exit.
Mon Mar 16 00:30:17 2020 daemon.info pppd[1664]: Exit.
Mon Mar 16 00:30:22 2020 daemon.info pppd[1839]: Exit.
Mon Mar 16 00:30:28 2020 daemon.info pppd[2070]: Exit.
Mon Mar 16 00:30:34 2020 daemon.info pppd[2302]: Exit.
Mon Mar 16 00:30:39 2020 daemon.info pppd[2533]: Exit.
Mon Mar 16 00:30:44 2020 daemon.info pppd[2622]: Exit.
Mon Mar 16 00:30:50 2020 daemon.info pppd[2829]: Exit.
Mon Mar 16 00:30:56 2020 daemon.info pppd[3024]: Exit.
Mon Mar 16 00:31:02 2020 daemon.info pppd[3247]: Exit.
Mon Mar 16 00:31:08 2020 daemon.info pppd[3469]: Exit.
Mon Mar 16 00:31:14 2020 daemon.info pppd[3708]: Exit.
Mon Mar 16 00:31:20 2020 daemon.info pppd[3891]: Exit.
Mon Mar 16 00:31:26 2020 daemon.info pppd[4116]: Exit.
Mon Mar 16 00:31:32 2020 daemon.info pppd[4349]: Exit.
Mon Mar 16 00:31:38 2020 daemon.info pppd[4530]: Exit.
Mon Mar 16 00:31:47 2020 daemon.info pppd[4825]: Exit.
Mon Mar 16 00:31:53 2020 daemon.info pppd[5033]: Exit.
Mon Mar 16 00:31:59 2020 daemon.info pppd[5262]: Exit.
Mon Mar 16 00:32:04 2020 daemon.info pppd[5492]: Exit.
Mon Mar 16 00:32:10 2020 daemon.info pppd[5666]: Exit.
Mon Mar 16 00:32:16 2020 daemon.info pppd[5907]: Exit.
Mon Mar 16 00:32:16 2020 daemon.notice netifd: Interface 'modem_1_1_2' is now down
Mon Mar 16 00:32:16 2020 daemon.notice netifd: Interface 'modem_1_1_2' is setting up now
Mon Mar 16 00:32:18 2020 daemon.notice netifd: modem_1_1_2 (5990): cat: can't open '/tmp/modem.1-1.2/signal': No such file or directory
Mon Mar 16 00:32:18 2020 daemon.notice pppd[6133]: pppd 2.4.7 started by root, uid 0
Mon Mar 16 00:32:19 2020 local2.info chat[6150]: abort on (BUSY)
Mon Mar 16 00:32:19 2020 local2.info chat[6150]: abort on (NO CARRIER)
Mon Mar 16 00:32:19 2020 local2.info chat[6150]: abort on (ERROR)
Mon Mar 16 00:32:19 2020 local2.info chat[6150]: report (CONNECT)
Mon Mar 16 00:32:19 2020 local2.info chat[6150]: timeout set to 10 seconds
Mon Mar 16 00:32:19 2020 local2.info chat[6150]: send (AT+CGDCONT=1,"IP","VZWINTERNET"^M)
Mon Mar 16 00:32:20 2020 local2.info chat[6150]: timeout set to 30 seconds
Mon Mar 16 00:32:20 2020 local2.info chat[6150]: expect (OK)
Mon Mar 16 00:32:20 2020 local2.info chat[6150]: ^M
Mon Mar 16 00:32:20 2020 local2.info chat[6150]: OK
Mon Mar 16 00:32:20 2020 local2.info chat[6150]: -- got it
Mon Mar 16 00:32:20 2020 local2.info chat[6150]: send (ATD*99***1#^M)
Mon Mar 16 00:32:20 2020 local2.info chat[6150]: expect (CONNECT)
Mon Mar 16 00:32:20 2020 local2.info chat[6150]: CONNECT
Mon Mar 16 00:32:20 2020 local2.info chat[6150]: send ( ^M)
Mon Mar 16 00:32:20 2020 daemon.info pppd[6133]: Serial connection established.
Mon Mar 16 00:32:20 2020 daemon.info pppd[6133]: Using interface 3g-modem_1_1_2
Mon Mar 16 00:32:20 2020 daemon.notice pppd[6133]: Connect: 3g-modem_1_1_2 <--> /dev/ttyUSB3
Mon Mar 16 00:32:20 2020 kern.info kernel: [14485.758158] 3g-modem_1_1_2: renamed from ppp0
Mon Mar 16 00:32:21 2020 daemon.notice pppd[6133]: Modem hangup
Mon Mar 16 00:32:21 2020 daemon.notice pppd[6133]: Connection terminated.
Mon Mar 16 00:32:22 2020 daemon.info pppd[6133]: Exit.
######## End Repeated Messages ########
Mon Mar 16 00:32:22 2020 daemon.notice netifd: Interface 'modem_1_1_2' is now down
Mon Mar 16 00:32:22 2020 daemon.notice netifd: Interface 'modem_1_1_2' is setting up now
Mon Mar 16 00:32:24 2020 daemon.notice netifd: modem_1_1_2 (6217): cat: can't open '/tmp/modem.1-1.2/signal': No such file or directory
Mon Mar 16 00:32:24 2020 daemon.notice pppd[6308]: pppd 2.4.7 started by root, uid 0
Mon Mar 16 00:32:25 2020 local2.info chat[6372]: abort on (BUSY)
Mon Mar 16 00:32:25 2020 local2.info chat[6372]: abort on (NO CARRIER)
Mon Mar 16 00:32:25 2020 local2.info chat[6372]: abort on (ERROR)
Mon Mar 16 00:32:25 2020 local2.info chat[6372]: report (CONNECT)
Mon Mar 16 00:32:25 2020 local2.info chat[6372]: timeout set to 10 seconds
Mon Mar 16 00:32:25 2020 local2.info chat[6372]: send (AT+CGDCONT=1,"IP","VZWINTERNET"^M)
Mon Mar 16 00:32:26 2020 local2.info chat[6372]: timeout set to 30 seconds
Mon Mar 16 00:32:26 2020 local2.info chat[6372]: expect (OK)
Mon Mar 16 00:32:26 2020 local2.info chat[6372]: ^M
Mon Mar 16 00:32:26 2020 local2.info chat[6372]: OK
Mon Mar 16 00:32:26 2020 local2.info chat[6372]: -- got it
Mon Mar 16 00:32:26 2020 local2.info chat[6372]: send (ATD*99***1#^M)
Mon Mar 16 00:32:26 2020 local2.info chat[6372]: expect (CONNECT)
Mon Mar 16 00:32:26 2020 local2.info chat[6372]: CONNECT
Mon Mar 16 00:32:26 2020 local2.info chat[6372]: send ( ^M)
Mon Mar 16 00:32:26 2020 daemon.info pppd[6308]: Serial connection established.
Mon Mar 16 00:32:26 2020 daemon.info pppd[6308]: Using interface 3g-modem_1_1_2
Mon Mar 16 00:32:28 2020 daemon.info pppd[6308]: Exit.
Mon Mar 16 00:32:28 2020 daemon.notice netifd: Interface 'modem_1_1_2' is now down
Mon Mar 16 00:32:28 2020 daemon.notice netifd: Interface 'modem_1_1_2' is setting up now
Mon Mar 16 00:32:30 2020 daemon.notice netifd: modem_1_1_2 (6445): cat: can't open '/tmp/modem.1-1.2/signal': No such file or directory
Mon Mar 16 00:32:30 2020 daemon.notice pppd[6537]: pppd 2.4.7 started by root, uid 0
Mon Mar 16 00:32:31 2020 local2.info chat[6554]: abort on (BUSY)
Mon Mar 16 00:32:31 2020 local2.info chat[6554]: abort on (NO CARRIER)
Mon Mar 16 00:32:31 2020 local2.info chat[6554]: abort on (ERROR)
Mon Mar 16 00:32:31 2020 local2.info chat[6554]: report (CONNECT)
Mon Mar 16 00:32:31 2020 local2.info chat[6554]: timeout set to 10 seconds
Mon Mar 16 00:32:31 2020 local2.info chat[6554]: send (AT+CGDCONT=1,"IP","VZWINTERNET"^M)
Mon Mar 16 00:32:32 2020 local2.info chat[6554]: timeout set to 30 seconds
Mon Mar 16 00:32:32 2020 local2.info chat[6554]: expect (OK)
Mon Mar 16 00:32:32 2020 local2.info chat[6554]: ^M
Mon Mar 16 00:32:32 2020 local2.info chat[6554]: OK
Mon Mar 16 00:32:32 2020 local2.info chat[6554]: -- got it
Mon Mar 16 00:32:32 2020 local2.info chat[6554]: send (ATD*99***1#^M)
Mon Mar 16 00:32:32 2020 local2.info chat[6554]: expect (CONNECT)
Mon Mar 16 00:32:32 2020 local2.info chat[6554]: CONNECT
Mon Mar 16 00:32:32 2020 local2.info chat[6554]: send ( ^M)
Mon Mar 16 00:32:32 2020 daemon.info pppd[6537]: Serial connection established.
Mon Mar 16 00:32:32 2020 daemon.info pppd[6537]: Using interface 3g-modem_1_1_2
Mon Mar 16 00:32:33 2020 daemon.notice pppd[6537]: local IP address <REMOVED>
Mon Mar 16 00:32:33 2020 daemon.notice pppd[6537]: remote IP address 10.64.64.64
Mon Mar 16 00:32:33 2020 daemon.notice pppd[6537]: primary DNS address 198.224.153.135
Mon Mar 16 00:32:33 2020 daemon.notice pppd[6537]: secondary DNS address 198.224.155.135
Mon Mar 16 00:32:33 2020 daemon.notice netifd: Network device '3g-modem_1_1_2' link is up
Mon Mar 16 00:32:33 2020 daemon.notice netifd: Interface 'modem_1_1_2' is now up
Mon Mar 16 00:32:33 2020 daemon.info dnsmasq[3031]: reading /tmp/resolv.conf.auto
Mon Mar 16 00:32:33 2020 daemon.info dnsmasq[3031]: using local addresses only for domain test
Mon Mar 16 00:32:33 2020 daemon.info dnsmasq[3031]: using local addresses only for domain onion
Mon Mar 16 00:32:33 2020 daemon.info dnsmasq[3031]: using local addresses only for domain localhost
Mon Mar 16 00:32:33 2020 daemon.info dnsmasq[3031]: using local addresses only for domain invalid
Mon Mar 16 00:32:33 2020 daemon.info dnsmasq[3031]: using local addresses only for domain bind
Mon Mar 16 00:32:33 2020 daemon.info dnsmasq[3031]: using local addresses only for domain lan
Mon Mar 16 00:32:33 2020 daemon.info dnsmasq[3031]: using nameserver 198.224.153.135#53
Mon Mar 16 00:32:33 2020 daemon.info dnsmasq[3031]: using nameserver 198.224.155.135#53
Mon Mar 16 00:32:38 2020 user.notice firewall: Reloading firewall due to ifup of modem_1_1_2 (3g-modem_1_1_2)
Mon Mar 16 00:33:03 2020 daemon.warn pppd[6537]: IPV6CP: timeout sending Config-Requests
Tue Mar 17 01:09:26 2020 daemon.info pppd[6537]: System time change detected.
Tue Mar 17 02:44:34 2020 daemon.info hostapd: wlan0: STA 8c:85:90:40:28:f5 IEEE 802.11: authenticated
Tue Mar 17 02:44:34 2020 daemon.info hostapd: wlan0: STA 8c:85:90:40:28:f5 IEEE 802.11: associated (aid 1)
Tue Mar 17 02:44:34 2020 daemon.notice hostapd: wlan0: AP-STA-CONNECTED 8c:85:90:40:28:f5
Tue Mar 17 02:44:34 2020 daemon.info hostapd: wlan0: STA 8c:85:90:40:28:f5 RADIUS: starting accounting session <REMOVED>
Tue Mar 17 02:44:34 2020 daemon.info hostapd: wlan0: STA 8c:85:90:40:28:f5 WPA: pairwise key handshake completed (RSN)
Tue Mar 17 02:44:37 2020 daemon.warn odhcpd[2390]: DHCPV6 SOLICIT IA_NA from <REMOVED> on br-lan: ok fd3f:2590:7039:10::683/128
Tue Mar 17 02:44:37 2020 daemon.info dnsmasq-dhcp[3031]: DHCPDISCOVER(br-lan) 8c:85:90:40:28:f5
Tue Mar 17 02:44:37 2020 daemon.info dnsmasq-dhcp[3031]: DHCPOFFER(br-lan) 192.168.8.200 8c:85:90:40:28:f5
Tue Mar 17 02:44:38 2020 daemon.warn odhcpd[2390]: DHCPV6 REQUEST IA_NA from <REMOVED> on br-lan: ok fd3f:2590:7039:10::683/128
Tue Mar 17 02:44:38 2020 daemon.info dnsmasq-dhcp[3031]: DHCPREQUEST(br-lan) 192.168.8.200 8c:85:90:40:28:f5
Tue Mar 17 02:44:38 2020 daemon.info dnsmasq-dhcp[3031]: DHCPACK(br-lan) 192.168.8.200 8c:85:90:40:28:f5 sis0134
Tue Mar 17 08:44:38 2020 daemon.info dnsmasq-dhcp[3031]: DHCPREQUEST(br-lan) 192.168.8.200 8c:85:90:40:28:f5
Tue Mar 17 08:44:38 2020 daemon.info dnsmasq-dhcp[3031]: DHCPACK(br-lan) 192.168.8.200 8c:85:90:40:28:f5 sis0134
Tue Mar 17 14:00:11 2020 daemon.info dnsmasq-dhcp[3031]: DHCPREQUEST(br-lan) 192.168.8.200 8c:85:90:40:28:f5
Tue Mar 17 14:00:11 2020 daemon.info dnsmasq-dhcp[3031]: DHCPACK(br-lan) 192.168.8.200 8c:85:90:40:28:f5 sis0134
Tue Mar 17 19:27:23 2020 daemon.info dnsmasq-dhcp[3031]: DHCPREQUEST(br-lan) 192.168.8.200 8c:85:90:40:28:f5
Tue Mar 17 19:27:23 2020 daemon.info dnsmasq-dhcp[3031]: DHCPACK(br-lan) 192.168.8.200 8c:85:90:40:28:f5 sis0134
Tue Mar 17 21:07:27 2020 daemon.info hostapd: wlan0: STA 8c:85:90:40:28:f5 WPA: group key handshake completed (RSN)
Wed Mar 18 00:59:51 2020 daemon.info dnsmasq-dhcp[3031]: DHCPREQUEST(br-lan) 192.168.8.200 8c:85:90:40:28:f5
Wed Mar 18 00:59:51 2020 daemon.info dnsmasq-dhcp[3031]: DHCPACK(br-lan) 192.168.8.200 8c:85:90:40:28:f5 sis0134
Wed Mar 18 06:18:25 2020 daemon.info dnsmasq-dhcp[3031]: DHCPREQUEST(br-lan) 192.168.8.200 8c:85:90:40:28:f5
Wed Mar 18 06:18:25 2020 daemon.info dnsmasq-dhcp[3031]: DHCPACK(br-lan) 192.168.8.200 8c:85:90:40:28:f5 sis0134
Wed Mar 18 11:53:34 2020 daemon.info dnsmasq-dhcp[3031]: DHCPREQUEST(br-lan) 192.168.8.200 8c:85:90:40:28:f5
Wed Mar 18 11:53:34 2020 daemon.info dnsmasq-dhcp[3031]: DHCPACK(br-lan) 192.168.8.200 8c:85:90:40:28:f5 sis0134
Wed Mar 18 17:13:27 2020 daemon.info dnsmasq-dhcp[3031]: DHCPREQUEST(br-lan) 192.168.8.200 8c:85:90:40:28:f5
Wed Mar 18 17:13:27 2020 daemon.info dnsmasq-dhcp[3031]: DHCPACK(br-lan) 192.168.8.200 8c:85:90:40:28:f5 sis0134
Wed Mar 18 21:07:27 2020 daemon.info hostapd: wlan0: STA 8c:85:90:40:28:f5 WPA: group key handshake completed (RSN)
Wed Mar 18 22:45:56 2020 daemon.info dnsmasq-dhcp[3031]: DHCPREQUEST(br-lan) 192.168.8.200 8c:85:90:40:28:f5
Wed Mar 18 22:45:56 2020 daemon.info dnsmasq-dhcp[3031]: DHCPACK(br-lan) 192.168.8.200 8c:85:90:40:28:f5 sis0134
Thu Mar 19 04:10:15 2020 daemon.info dnsmasq-dhcp[3031]: DHCPREQUEST(br-lan) 192.168.8.200 8c:85:90:40:28:f5
Thu Mar 19 04:10:15 2020 daemon.info dnsmasq-dhcp[3031]: DHCPACK(br-lan) 192.168.8.200 8c:85:90:40:28:f5 sis0134
Thu Mar 19 09:39:46 2020 daemon.info dnsmasq-dhcp[3031]: DHCPREQUEST(br-lan) 192.168.8.200 8c:85:90:40:28:f5
Thu Mar 19 09:39:46 2020 daemon.info dnsmasq-dhcp[3031]: DHCPACK(br-lan) 192.168.8.200 8c:85:90:40:28:f5 sis0134
