Spitz (GL-X750V2) snapshot firmware custom rules section?
Ok i have the Spitz (GL-X750V2) 4G LTE Smart Gateway on the stable firmware Version: 3.217 i can go to More Settings>Advanced>Luci> 192.168.8.1/cgi-bin/luci>Network>Firewall>Custom Rules. and there i can paste my iptables there and save and reboot and then everything is where it needs to be. I decided to try out the snapshot Version: 4.3.2 and it installed fine but tried to repeat the same process but could not find the Custom rules section. Was it removed? or moved? Any help would be great because i loved the new look and feel of it.
OpenWrt22.03 uses firewall4 (nftables), Custom Rules in luci have been removed, you can refer to this to add custom rules.
ok thank you seems to be more complex but ill try to figure it out… ok so yea how do i start to go about doing this ??
