Spitz X-3000 correct antenna orientation when flat on the wall
When using the Spitz vertically flat on a wall with all antennas straight up, the middle 5G antennas should be flat or perpendicular to the wall for best reception?
Unless you are trying to receive cellular signals from space I’d say they should be vertical.
