Hi, is it possible to set split tunneling on the Beryl AX? I am using AdGuard Home and OpenVPN and I want the traffic of a website to go through the normal connection, without VPN, the traffic from YouTube in this case.
I’ve done some research but nothing is clear, I’d appreciate any detail, thank you.
Hello
You have to set the global proxy to - Policy Mode
Based on the target domain or IP.
In this mode, only traffic from specific websites defined by IP address or domain name will be routed through the VPN. Only one VPN client instance can be enabled.
Change.
Here you can enter an IP that does not pass or only passes through the tunnel.
