Split tunneling
Good afternoon,
On a Brume 3 (GL-MT5000) how do I configure WireGuard to enable split tunnelling so I can let a couple of devices bypass the VPN tunnel, please? Thanks and kind regards
Please refer to:
In short, go to Admin Panel → VPN → VPN Dashboard, switch to Policy Mode, then under From, select Exclude Specified Devices and add the devices you want to bypass the VPN.
Thank you :wink:
