I dont know much about SQM but reading a little bit i set the following (below attached) configuration on my flint trough lucy, however i have an issue. The setting is lost every time i reboot the flint. I mean, regardless the correct setup is ok in the interface, the speed is way higher than the set speed. it only will work again if i change any download or upload speed value, click save an apply and connection start to works as desired.
Other question. I realize the download and upload value to set are inverted. the value i set as upload works as my download speed limit and the value set as download works as upload. is this ok?
i want to limit the bandwith for my guest network for every device without having manually to limit each of them in the flint interface.
