SSD failing as network storage
I had been using a 2TB Sandisk Extreme SSD as network storage, formatted as NTFS, attached to the Slate AX and it has been working fine. I upgraded to a 4TB of the same drive for extra space, it worked fine for a few days then it started failing when uploading/writing to it.
I tried many restarts, firmware downgrades/upgrades, reformatting the SSD to exFAT, ext4, all to no avail. At the same time I've been trying to update tailscale and running out of internal storage to do this, so added an SD card as extroot, which helped with storage but the SSD problem remained.
Copying small files seemed to work, large files/folders would fail at some point in the process, not always at a specific percentage.
I eventually thought maybe the 4TB SSD requires more power and that's why the writing fails. I tried connecting the SSD through a USB C hub with external power attached and the hub attached to the router via USB C to USB A adapter. It seemed to work, so I bought a powered USB 3 hub with which I've tested the SSD connecting it to USB chargers of various powers and cables, but the problem persists. I retried the same setup that worked before but now it doesn't work again.
I tested the SSD itself by writing to it to full when connected directly to the computer but got no errors
I got some logs with the errors that come up when this problem occurs, hoping someone can guide where the problem is.
I can see write errors, some I/O errors, remounting, kernel device errors, and samba restarting after the device remounts from /dev/sda2 to /dev/sdb2 or vice versa.
I'm not very experienced with such things but I'm trying to learn, so apologies if the solution is obvious and I've missed it. Is the router just incapable of running a 4TB SSD, or is the SSD bad somehow, or is there a setting I'm missing? Please help.
> Fri Dec 20 23:53:50 2024 daemon.notice ntfs-3g[16067]: Incomplete multi-sector transfer: magic: 0x454c4946  size: 1024  usa_ofs: 48  usa_count: 2  data: 291  usn: 292: I/O error
> Fri Dec 20 23:53:50 2024 daemon.notice ntfs-3g[16067]: Record 2418 has no FILE magic (0x44414142)
> Fri Dec 20 23:53:54 2024 daemon.notice ntfs-3g[16067]: Incomplete multi-sector transfer: magic: 0x454c4946  size: 1024  usa_ofs: 48  usa_count: 2  data: 291  usn: 292: I/O error
> Fri Dec 20 23:53:54 2024 daemon.notice ntfs-3g[16067]: Record 2418 has no FILE magic (0x44414142)
> Fri Dec 20 23:53:55 2024 daemon.notice ntfs-3g[16067]: Incomplete multi-sector transfer: magic: 0x454c4946  size: 1024  usa_ofs: 48  usa_count: 2  data: 291  usn: 292: I/O error
> Fri Dec 20 23:53:55 2024 daemon.notice ntfs-3g[16067]: Record 2418 has no FILE magic (0x44414142)
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  638.796431] sd 3:0:0:0: [sda] tag#5 data cmplt err -71 uas-tag 6 inflight: CMD
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  638.796472] sd 3:0:0:0: [sda] tag#5 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 4c 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.802564] usb 2-1.1: cmd cmplt err -71
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.811992] xhci-hcd xhci-hcd.0.auto: ERROR Transfer event for disabled endpoint or incorrect stream ring
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.815834] xhci-hcd xhci-hcd.0.auto: @000000005e631ae0 00000000 00000000 04000000 04068000
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.825300] usb 2-1.1: cmd cmplt err -71
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.833506] usb 2-1.1: cmd cmplt err -71
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.837667] usb 2-1.1: cmd cmplt err -71
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.841573] usb 2-1.1: cmd cmplt err -71
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.845513] usb 2-1.1: cmd cmplt err -71
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.849402] usb 2-1.1: cmd cmplt err -71
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  638.856035] usb 2-1.1: USB disconnect, device number 7
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.857457] xhci-hcd xhci-hcd.0.auto: ERROR Transfer event for disabled endpoint or incorrect stream ring
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.862101] xhci-hcd xhci-hcd.0.auto: @000000005e631c50 00000000 00000000 1b000000 04098000
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  638.872696] sd 3:0:0:0: [sda] tag#0 uas_zap_pending 0 uas-tag 1 inflight: CMD
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  638.879896] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 64 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  638.887192] sd 3:0:0:0: [sda] tag#1 uas_zap_pending 0 uas-tag 2 inflight: CMD
> Fri Dec 20 23:54:27 2024 kern.warn kernel: [  638.887244] scsi_io_completion: 40 callbacks suppressed
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  638.887252] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  638.887259] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 64 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.warn kernel: [  638.887262] blk_update_request: 40 callbacks suppressed
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.887265] blk_update_request: I/O error, dev sda, sector 2740610064
> Fri Dec 20 23:54:27 2024 kern.warn kernel: [  638.887269] buffer_io_error: 8319 callbacks suppressed
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.887273] Buffer I/O error on dev sda2, logical block 342524802, lost async page write
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.887286] Buffer I/O error on dev sda2, logical block 342524803, lost async page write
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.887292] Buffer I/O error on dev sda2, logical block 342524804, lost async page write
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.887297] Buffer I/O error on dev sda2, logical block 342524805, lost async page write
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.887302] Buffer I/O error on dev sda2, logical block 342524806, lost async page write
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.887307] Buffer I/O error on dev sda2, logical block 342524807, lost async page write
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.887312] Buffer I/O error on dev sda2, logical block 342524808, lost async page write
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.887317] Buffer I/O error on dev sda2, logical block 342524809, lost async page write
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.887323] Buffer I/O error on dev sda2, logical block 342524810, lost async page write
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  638.887327] Buffer I/O error on dev sda2, logical block 342524811, lost async page write
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.015569] sd 3:0:0:0: [sda] tag#1 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 78 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.023648] sd 3:0:0:0: [sda] tag#2 uas_zap_pending 0 uas-tag 3 inflight: CMD
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.023695] sd 3:0:0:0: [sda] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.023702] sd 3:0:0:0: [sda] tag#1 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 78 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  639.023705] blk_update_request: I/O error, dev sda, sector 2740615184
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.057233] sd 3:0:0:0: [sda] tag#2 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 7c 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.063578] sd 3:0:0:0: [sda] tag#3 uas_zap_pending 0 uas-tag 4 inflight: CMD
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.063624] sd 3:0:0:0: [sda] tag#2 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.063631] sd 3:0:0:0: [sda] tag#2 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 7c 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  639.063634] blk_update_request: I/O error, dev sda, sector 2740616208
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.097250] sd 3:0:0:0: [sda] tag#3 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 80 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.103596] sd 3:0:0:0: [sda] tag#4 uas_zap_pending 0 uas-tag 5 inflight: CMD
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.103638] sd 3:0:0:0: [sda] tag#3 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.103644] sd 3:0:0:0: [sda] tag#3 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 80 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  639.103647] blk_update_request: I/O error, dev sda, sector 2740617232
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.137267] sd 3:0:0:0: [sda] tag#4 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 84 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.143612] sd 3:0:0:0: [sda] tag#5 uas_zap_pending 0 uas-tag 6 inflight: CMD
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.143655] sd 3:0:0:0: [sda] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.143662] sd 3:0:0:0: [sda] tag#4 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 84 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  639.143665] blk_update_request: I/O error, dev sda, sector 2740618256
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.177285] sd 3:0:0:0: [sda] tag#5 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 4c 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.183629] sd 3:0:0:0: [sda] tag#6 uas_zap_pending 0 uas-tag 7 inflight: CMD
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.183673] sd 3:0:0:0: [sda] tag#5 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.183679] sd 3:0:0:0: [sda] tag#5 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 4c 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  639.183682] blk_update_request: I/O error, dev sda, sector 2740603920
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.217302] sd 3:0:0:0: [sda] tag#6 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 50 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.223647] sd 3:0:0:0: [sda] tag#7 uas_zap_pending 0 uas-tag 8 inflight: CMD
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.223690] sd 3:0:0:0: [sda] tag#6 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.223697] sd 3:0:0:0: [sda] tag#6 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 50 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  639.223700] blk_update_request: I/O error, dev sda, sector 2740604944
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.257320] sd 3:0:0:0: [sda] tag#7 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 54 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.263664] sd 3:0:0:0: [sda] tag#8 uas_zap_pending 0 uas-tag 9 inflight: CMD
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.263708] sd 3:0:0:0: [sda] tag#7 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.263715] sd 3:0:0:0: [sda] tag#7 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 54 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  639.263718] blk_update_request: I/O error, dev sda, sector 2740605968
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.297337] sd 3:0:0:0: [sda] tag#8 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 58 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.303683] sd 3:0:0:0: [sda] tag#9 uas_zap_pending 0 uas-tag 10 inflight: CMD
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.303724] sd 3:0:0:0: [sda] tag#8 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.303730] sd 3:0:0:0: [sda] tag#8 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 58 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  639.303734] blk_update_request: I/O error, dev sda, sector 2740606992
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.337441] sd 3:0:0:0: [sda] tag#9 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 5c 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.343785] sd 3:0:0:0: [sda] tag#11 uas_zap_pending 0 uas-tag 11 inflight: CMD
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.343827] sd 3:0:0:0: [sda] tag#9 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.343833] sd 3:0:0:0: [sda] tag#9 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 5c 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.err kernel: [  639.343837] blk_update_request: I/O error, dev sda, sector 2740608016
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.377632] sd 3:0:0:0: [sda] tag#11 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 68 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.383977] sd 3:0:0:0: [sda] tag#12 uas_zap_pending 0 uas-tag 12 inflight: CMD
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.393171] sd 3:0:0:0: [sda] tag#12 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 6c 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.400644] sd 3:0:0:0: [sda] tag#13 uas_zap_pending 0 uas-tag 13 inflight: CMD
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.409753] sd 3:0:0:0: [sda] tag#13 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 70 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.417223] sd 3:0:0:0: [sda] tag#14 uas_zap_pending 0 uas-tag 14 inflight: CMD
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.426332] sd 3:0:0:0: [sda] tag#14 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 74 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.433804] sd 3:0:0:0: [sda] tag#10 uas_zap_pending 0 uas-tag 15 inflight: CMD
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.442911] sd 3:0:0:0: [sda] tag#10 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 60 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.450382] sd 3:0:0:0: [sda] tag#15 uas_zap_pending 0 uas-tag 16 inflight: CMD
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.459492] sd 3:0:0:0: [sda] tag#15 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 88 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.466964] sd 3:0:0:0: [sda] tag#16 uas_zap_pending 0 uas-tag 17 inflight: CMD
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.476071] sd 3:0:0:0: [sda] tag#16 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 8c 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.483543] sd 3:0:0:0: [sda] tag#17 uas_zap_pending 0 uas-tag 18 inflight: CMD
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.492652] sd 3:0:0:0: [sda] tag#17 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 90 10 00 00 04 00 00 00
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.500123] sd 3:0:0:0: [sda] tag#18 uas_zap_pending 0 uas-tag 19 inflight: CMD
> Fri Dec 20 23:54:27 2024 kern.info kernel: [  639.509231] sd 3:0:0:0: [sda] tag#18 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 5a 94 10 00 00 04 00 00 00
> Fri Dec 20 23:54:28 2024 kern.notice kernel: [  639.615122] sd 3:0:0:0: [sda] Synchronizing SCSI cache
> Fri Dec 20 23:54:28 2024 kern.info kernel: [  639.861783] sd 3:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=0x00
> Fri Dec 20 23:54:28 2024 kern.info kernel: [  640.161787] usb 2-1.1: new SuperSpeed USB device number 8 using xhci-hcd
> Fri Dec 20 23:54:28 2024 kern.info kernel: [  640.185201] scsi host4: uas
> Fri Dec 20 23:54:28 2024 daemon.err nmbd[17493]: [2024/12/20 23:54:28.702131,  0] ../../source3/nmbd/nmbd.c:60(terminate)
> Fri Dec 20 23:54:28 2024 daemon.err nmbd[17493]:   Got SIGTERM: going down...
> Fri Dec 20 23:54:28 2024 kern.notice kernel: [  640.233950] scsi 4:0:0:0: Direct-Access     SanDisk  Extreme 55DD     0030 PQ: 0 ANSI: 6
> Fri Dec 20 23:54:28 2024 kern.notice kernel: [  640.279891] scsi 4:0:0:1: Enclosure         SanDisk  SES Device       0030 PQ: 0 ANSI: 6
> Fri Dec 20 23:54:28 2024 kern.notice kernel: [  640.284918] sd 4:0:0:0: [sdb] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
> Fri Dec 20 23:54:28 2024 kern.notice kernel: [  640.287094] sd 4:0:0:0: [sdb] 4096-byte physical blocks
> Fri Dec 20 23:54:28 2024 kern.notice kernel: [  640.314903] sd 4:0:0:0: [sdb] Write Protect is off
> Fri Dec 20 23:54:28 2024 kern.debug kernel: [  640.314936] sd 4:0:0:0: [sdb] Mode Sense: 3d 00 10 00
> Fri Dec 20 23:54:28 2024 kern.notice kernel: [  640.316938] sd 4:0:0:0: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
> Fri Dec 20 23:54:28 2024 kern.err kernel: [  640.318790] xhci-hcd xhci-hcd.0.auto: ERROR Transfer event for disabled endpoint or incorrect stream ring
> Fri Dec 20 23:54:28 2024 kern.err kernel: [  640.327202] xhci-hcd xhci-hcd.0.auto: @000000005e6314f0 00000000 00000000 1b000000 04058001
> Fri Dec 20 23:54:28 2024 kern.info kernel: [  640.364004]  sdb: sdb1 sdb2
> Fri Dec 20 23:54:28 2024 kern.notice kernel: [  640.376268] sd 4:0:0:0: [sdb] Attached SCSI disk
> Fri Dec 20 23:54:28 2024 daemon.notice ntfs-3g[16067]: Unmounting /dev/sda2 (ExtremeSSD4)
> Fri Dec 20 23:54:28 2024 daemon.notice ntfs-3g[16067]: Failed to sync device /dev/sda2: I/O error
> Fri Dec 20 23:54:28 2024 daemon.notice ntfs-3g[16067]: Failed to fsync device /dev/sda2: I/O error
> Fri Dec 20 23:54:28 2024 daemon.notice ntfs-3g[16067]: Failed to close volume /dev/sda2: Resource busy
> Fri Dec 20 23:54:28 2024 daemon.err tailscaled[10094]: 2024/12/20 23:54:28 [RATELIMIT] format("monitor: ip rule deleted: %+v") (7 dropped)
> Fri Dec 20 23:54:28 2024 daemon.err tailscaled[10094]: 2024/12/20 23:54:28 monitor: ip rule deleted: {Family:2 DstLength:0 SrcLength:0 Tos:0 Table:254 Protocol:0 Scope:0 Type:1 Flags:0 Attributes:{Dst:<nil> Src:<nil> Gateway:<nil> OutIface:0 Priority:1100 Table:254 Mark:0 Pref:<nil> Expires:<nil> Metrics:<nil> Multipath:[]}}
> Fri Dec 20 23:54:28 2024 daemon.err tailscaled[10094]: 2024/12/20 23:54:28 monitor: ip rule deleted: {Family:2 DstLength:0 SrcLength:0 Tos:0 Table:64 Protocol:0 Scope:0 Type:1 Flags:2 Attributes:{Dst:<nil> Src:<nil> Gateway:<nil> OutIface:0 Priority:1101 Table:8000 Mark:49152 Pref:<nil> Expires:<nil> Metrics:<nil> Multipath:[]}}
> Fri Dec 20 23:54:28 2024 daemon.err tailscaled[10094]: 2024/12/20 23:54:28 monitor: ip rule deleted: {Family:2 DstLength:0 SrcLength:0 Tos:0 Table:254 Protocol:0 Scope:0 Type:1 Flags:0 Attributes:{Dst:<nil> Src:<nil> Gateway:<nil> OutIface:0 Priority:1099 Table:254 Mark:786432 Pref:<nil> Expires:<nil> Metrics:<nil> Multipath:[]}}
> Fri Dec 20 23:54:29 2024 kern.warn kernel: [  640.598553] VFS: Dirty inode writeback failed for block device sda2 (err=-5).
> Fri Dec 20 23:54:29 2024 daemon.err tailscaled[10094]: 2024/12/20 23:54:29 monitor: ip rule deleted: {Family:2 DstLength:0 SrcLength:0 Tos:0 Table:254 Protocol:0 Scope:0 Type:1 Flags:0 Attributes:{Dst:<nil> Src:<nil> Gateway:<nil> OutIface:0 Priority:1100 Table:254 Mark:0 Pref:<nil> Expires:<nil> Metrics:<nil> Multipath:[]}}
> Fri Dec 20 23:54:29 2024 daemon.err tailscaled[10094]: 2024/12/20 23:54:29 monitor: ip rule deleted: {Family:2 DstLength:0 SrcLength:0 Tos:0 Table:64 Protocol:0 Scope:0 Type:1 Flags:2 Attributes:{Dst:<nil> Src:<nil> Gateway:<nil> OutIface:0 Priority:1101 Table:8000 Mark:49152 Pref:<nil> Expires:<nil> Metrics:<nil> Multipath:[]}}
> Fri Dec 20 23:54:29 2024 daemon.err tailscaled[10094]: 2024/12/20 23:54:29 [RATELIMIT] format("monitor: ip rule deleted: %+v")
> Fri Dec 20 23:54:30 2024 daemon.err nmbd[18339]: [2024/12/20 23:54:30.224861,  0] ../../lib/util/become_daemon.c:136(daemon_ready)
> Fri Dec 20 23:54:30 2024 daemon.err nmbd[18339]:   daemon_ready: daemon 'nmbd' finished starting up and ready to serve connections
> Fri Dec 20 23:54:30 2024 daemon.err nmbd[18339]: [2024/12/20 23:54:30.225596,  0] ../../source3/nmbd/nmbd_become_dmb.c:294(become_domain_master_browser_bcast)
> Fri Dec 20 23:54:30 2024 daemon.err nmbd[18339]:   become_domain_master_browser_bcast:
> Fri Dec 20 23:54:30 2024 daemon.err nmbd[18339]:   Attempting to become domain master browser on workgroup WORKGROUP on subnet 192.168.10.1
> Fri Dec 20 23:54:30 2024 daemon.err nmbd[18339]: [2024/12/20 23:54:30.225916,  0] ../../source3/nmbd/nmbd_become_dmb.c:307(become_domain_master_browser_bcast)
> Fri Dec 20 23:54:30 2024 daemon.err nmbd[18339]:   become_domain_master_browser_bcast: querying subnet 192.168.10.1 for domain master browser on workgroup WORKGROUP
> Fri Dec 20 23:54:30 2024 daemon.err smbd[18338]: [2024/12/20 23:54:30.300346,  0] ../../lib/util/become_daemon.c:136(daemon_ready)
> Fri Dec 20 23:54:30 2024 daemon.err smbd[18338]:   daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
> Fri Dec 20 23:54:30 2024 daemon.err nmbd[18339]: [2024/12/20 23:54:30.757136,  0] ../../source3/nmbd/nmbd.c:60(terminate)
> Fri Dec 20 23:54:30 2024 daemon.err nmbd[18339]:   Got SIGTERM: going down...
> Fri Dec 20 23:54:31 2024 daemon.err nmbd[18990]: [2024/12/20 23:54:31.271952,  0] ../../lib/util/become_daemon.c:136(daemon_ready)
> Fri Dec 20 23:54:31 2024 daemon.err nmbd[18990]:   daemon_ready: daemon 'nmbd' finished starting up and ready to serve connections
> Fri Dec 20 23:54:31 2024 daemon.err nmbd[18990]: [2024/12/20 23:54:31.272781,  0] ../../source3/nmbd/nmbd_become_dmb.c:294(become_domain_master_browser_bcast)
> Fri Dec 20 23:54:31 2024 daemon.err nmbd[18990]:   become_domain_master_browser_bcast:
> Fri Dec 20 23:54:31 2024 daemon.err nmbd[18990]:   Attempting to become domain master browser on workgroup WORKGROUP on subnet 192.168.10.1
> Fri Dec 20 23:54:31 2024 daemon.err nmbd[18990]: [2024/12/20 23:54:31.273014,  0] ../../source3/nmbd/nmbd_become_dmb.c:307(become_domain_master_browser_bcast)
> Fri Dec 20 23:54:31 2024 daemon.err nmbd[18990]:   become_domain_master_browser_bcast: querying subnet 192.168.10.1 for domain master browser on workgroup WORKGROUP
> Fri Dec 20 23:54:31 2024 daemon.err smbd[18989]: [2024/12/20 23:54:31.375327,  0] ../../lib/util/become_daemon.c:136(daemon_ready)
> Fri Dec 20 23:54:31 2024 daemon.err smbd[18989]:   daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
> Fri Dec 20 23:54:31 2024 daemon.notice ntfs-3g[19091]: Version 2017.3.23 integrated FUSE 27
> Fri Dec 20 23:54:31 2024 daemon.notice ntfs-3g[19091]: Mounted /dev/sdb2 (Read-Write, label "ExtremeSSD4", NTFS 3.1)
> Fri Dec 20 23:54:31 2024 daemon.notice ntfs-3g[19091]: Cmdline options: noatime,big_writes,async,force
> Fri Dec 20 23:54:31 2024 daemon.notice ntfs-3g[19091]: Mount options: async,force,allow_other,nonempty,noatime,fsname=/dev/sdb2,blkdev,blksize=4096
> Fri Dec 20 23:54:31 2024 daemon.notice ntfs-3g[19091]: Ownership and permissions disabled, configuration type 1
> Fri Dec 20 23:54:39 2024 daemon.err nmbd[18990]: [2024/12/20 23:54:39.289710,  0] ../../source3/nmbd/nmbd_become_dmb.c:112(become_domain_master_stage2)
> Fri Dec 20 23:54:39 2024 daemon.err nmbd[18990]:   *****
> Fri Dec 20 23:54:39 2024 daemon.err nmbd[18990]:   Samba server GL-AXT1800 is now a domain master browser for workgroup WORKGROUP on subnet 192.168.10.1
> Fri Dec 20 23:54:54 2024 daemon.err nmbd[18990]: [2024/12/20 23:54:54.310850,  0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
> Fri Dec 20 23:54:54 2024 daemon.err nmbd[18990]:   *****
> Fri Dec 20 23:54:54 2024 daemon.err nmbd[18990]:   Samba name server GL-AXT1800 is now a local master browser for workgroup WORKGROUP on subnet 192.168.10.1
More logs below..
More logs:
P.S. I did try swapping cables and the problem persists.
> Fri Dec 20 23:03:42 2024 kern.err kernel: [  214.058007] xhci-hcd xhci-hcd.0.auto: ERROR Transfer event for disabled endpoint or incorrect stream ring
> Fri Dec 20 23:03:42 2024 kern.err kernel: [  214.058053] xhci-hcd xhci-hcd.0.auto: @000000005e607860 00000000 00000000 04000000 03098001
> Fri Dec 20 23:03:42 2024 kern.err kernel: [  214.069142] xhci-hcd xhci-hcd.0.auto: ERROR Transfer event for disabled endpoint or incorrect stream ring
> Fri Dec 20 23:03:42 2024 kern.err kernel: [  214.074728] xhci-hcd xhci-hcd.0.auto: @000000005e607870 00000000 00000000 04000000 03068001
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.094179] sd 0:0:0:0: [sda] tag#27 uas_eh_abort_handler 0 uas-tag 28 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.094220] sd 0:0:0:0: [sda] tag#27 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4c 2b 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.101473] sd 0:0:0:0: [sda] tag#5 uas_eh_abort_handler 0 uas-tag 6 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.110538] sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4b d3 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.118642] sd 0:0:0:0: [sda] tag#26 uas_eh_abort_handler 0 uas-tag 27 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.127728] sd 0:0:0:0: [sda] tag#26 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4c 27 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.135979] sd 0:0:0:0: [sda] tag#4 uas_eh_abort_handler 0 uas-tag 5 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.145001] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4b cf 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.153067] sd 0:0:0:0: [sda] tag#25 uas_eh_abort_handler 0 uas-tag 26 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.162189] sd 0:0:0:0: [sda] tag#25 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4c 23 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.170546] sd 0:0:0:0: [sda] tag#3 uas_eh_abort_handler 0 uas-tag 4 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.179464] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4b cb 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.187416] sd 0:0:0:0: [sda] tag#24 uas_eh_abort_handler 0 uas-tag 25 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.196651] sd 0:0:0:0: [sda] tag#24 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4c 1f 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.204889] sd 0:0:0:0: [sda] tag#2 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.213926] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4b c7 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.221868] sd 0:0:0:0: [sda] tag#23 uas_eh_abort_handler 0 uas-tag 24 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.231112] sd 0:0:0:0: [sda] tag#23 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4c 1b 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.239293] sd 0:0:0:0: [sda] tag#1 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.248386] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4b c3 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.256405] sd 0:0:0:0: [sda] tag#22 uas_eh_abort_handler 0 uas-tag 23 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.265574] sd 0:0:0:0: [sda] tag#22 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4c 17 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.273847] sd 0:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.282848] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4b bf 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.290385] sd 0:0:0:0: [sda] tag#21 uas_eh_abort_handler 0 uas-tag 22 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.299690] sd 0:0:0:0: [sda] tag#21 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4c 13 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.307970] sd 0:0:0:0: [sda] tag#20 uas_eh_abort_handler 0 uas-tag 21 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.316963] sd 0:0:0:0: [sda] tag#20 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4c 0f 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.325234] sd 0:0:0:0: [sda] tag#19 uas_eh_abort_handler 0 uas-tag 20 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.334325] sd 0:0:0:0: [sda] tag#19 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4c 0b 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.342639] sd 0:0:0:0: [sda] tag#18 uas_eh_abort_handler 0 uas-tag 19 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.351702] sd 0:0:0:0: [sda] tag#18 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4c 07 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.360261] sd 0:0:0:0: [sda] tag#17 uas_eh_abort_handler 0 uas-tag 18 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.369056] sd 0:0:0:0: [sda] tag#17 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4c 03 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.377471] sd 0:0:0:0: [sda] tag#16 uas_eh_abort_handler 0 uas-tag 17 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.386419] sd 0:0:0:0: [sda] tag#16 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4b ff 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.394776] sd 0:0:0:0: [sda] tag#15 uas_eh_abort_handler 0 uas-tag 16 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.403770] sd 0:0:0:0: [sda] tag#15 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4b fb 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.412122] sd 0:0:0:0: [sda] tag#14 uas_eh_abort_handler 0 uas-tag 15 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.421131] sd 0:0:0:0: [sda] tag#14 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4b f7 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.429423] sd 0:0:0:0: [sda] tag#13 uas_eh_abort_handler 0 uas-tag 14 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.438491] sd 0:0:0:0: [sda] tag#13 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4b f3 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.446933] sd 0:0:0:0: [sda] tag#12 uas_eh_abort_handler 0 uas-tag 13 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.455856] sd 0:0:0:0: [sda] tag#12 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4b ef 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.464285] sd 0:0:0:0: [sda] tag#11 uas_eh_abort_handler 0 uas-tag 12 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.473217] sd 0:0:0:0: [sda] tag#11 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4b eb 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.481608] sd 0:0:0:0: [sda] tag#10 uas_eh_abort_handler 0 uas-tag 11 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.490577] sd 0:0:0:0: [sda] tag#10 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4b e7 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.498934] sd 0:0:0:0: [sda] tag#9 uas_eh_abort_handler 0 uas-tag 10 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.507936] sd 0:0:0:0: [sda] tag#9 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4b e3 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.516212] sd 0:0:0:0: [sda] tag#8 uas_eh_abort_handler 0 uas-tag 9 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.525214] sd 0:0:0:0: [sda] tag#8 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4b df 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.533065] sd 0:0:0:0: [sda] tag#7 uas_eh_abort_handler 0 uas-tag 8 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.542315] sd 0:0:0:0: [sda] tag#7 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4b db 50 00 00 04 00 00 00
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.551166] sd 0:0:0:0: [sda] tag#6 uas_eh_abort_handler 0 uas-tag 7 inflight: CMD OUT
> Fri Dec 20 23:04:12 2024 kern.info kernel: [  244.559418] sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x8a 8a 00 00 00 00 00 a3 4b d7 50 00 00 04 00 00 00
> Fri Dec 20 23:04:14 2024 kern.info kernel: [  246.044186] sd 0:0:0:0: tag#28 uas_eh_abort_handler 0 uas-tag 29 inflight: CMD
> Fri Dec 20 23:04:14 2024 kern.info kernel: [  246.044223] sd 0:0:0:0: tag#28 CDB: opcode=0x0 00 00 00 00 00 00
> Fri Dec 20 23:04:14 2024 kern.info kernel: [  246.050318] scsi host0: uas_eh_device_reset_handler start
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.056626] usb 2-1.1: cmd cmplt err -2
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.061853] usb 2-1.1: cmd cmplt err -71
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.065494] usb 2-1.1: cmd cmplt err -2
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.069676] usb 2-1.1: cmd cmplt err -2
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.073220] usb 2-1.1: cmd cmplt err -71
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.077037] usb 2-1.1: cmd cmplt err -2
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.081220] usb 2-1.1: cmd cmplt err -2
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.084778] usb 2-1.1: cmd cmplt err -2
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.088597] usb 2-1.1: cmd cmplt err -2
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.092417] usb 2-1.1: cmd cmplt err -2
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.096237] usb 2-1.1: cmd cmplt err -2
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.100060] usb 2-1.1: cmd cmplt err -2
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.103875] usb 2-1.1: cmd cmplt err -2
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.107696] usb 2-1.1: cmd cmplt err -2
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.111528] usb 2-1.1: cmd cmplt err -2
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.115334] usb 2-1.1: cmd cmplt err -2
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.119154] usb 2-1.1: cmd cmplt err -2
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.122974] usb 2-1.1: cmd cmplt err -2
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.126793] usb 2-1.1: cmd cmplt err -2
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.130613] usb 2-1.1: cmd cmplt err -2
> Fri Dec 20 23:04:14 2024 kern.err kernel: [  246.134433] usb 2-1.1: cmd cmplt err -2
> Fri Dec 20 23:04:19 2024 kern.err kernel: [  251.134246] hub 2-1:1.0: hub_port_status failed (err = -110)
> Fri Dec 20 23:04:20 2024 kern.err kernel: [  252.134210] usb 2-1-port1: cannot reset (err = -110)
> Fri Dec 20 23:04:21 2024 kern.err kernel: [  253.134210] usb 2-1-port1: cannot reset (err = -110)
> Fri Dec 20 23:04:22 2024 kern.err kernel: [  254.134204] usb 2-1-port1: cannot reset (err = -110)
> Fri Dec 20 23:04:23 2024 kern.err kernel: [  255.134202] usb 2-1-port1: cannot reset (err = -110)
> Fri Dec 20 23:04:24 2024 kern.err kernel: [  256.134167] usb 2-1-port1: cannot reset (err = -110)
> Fri Dec 20 23:04:24 2024 kern.err kernel: [  256.134193] usb 2-1-port1: Cannot enable. Maybe the USB cable is bad?
> Fri Dec 20 23:04:25 2024 kern.err kernel: [  257.134188] usb 2-1-port1: cannot disable (err = -110)
> Fri Dec 20 23:04:30 2024 kern.err kernel: [  262.134151] hub 2-1:1.0: hub_port_status failed (err = -110)
> Fri Dec 20 23:04:30 2024 authpriv.info dropbear[11054]: Child connection from 192.168.10.198:65397
> Fri Dec 20 23:04:30 2024 authpriv.info dropbear[11054]: Exit before auth from <192.168.10.198:65397>: Exited normally
> Fri Dec 20 23:04:31 2024 kern.err kernel: [  263.134137] usb 2-1-port1: cannot reset (err = -110)
> Fri Dec 20 23:04:32 2024 kern.err kernel: [  264.134130] usb 2-1-port1: cannot reset (err = -110)
> Fri Dec 20 23:04:33 2024 kern.err kernel: [  265.134126] usb 2-1-port1: cannot reset (err = -110)
> Fri Dec 20 23:04:34 2024 kern.err kernel: [  266.134127] usb 2-1-port1: cannot reset (err = -110)
> Fri Dec 20 23:04:35 2024 kern.err kernel: [  267.134117] usb 2-1-port1: cannot reset (err = -110)
> Fri Dec 20 23:04:35 2024 kern.err kernel: [  267.134144] usb 2-1-port1: Cannot enable. Maybe the USB cable is bad?
> Fri Dec 20 23:04:36 2024 kern.err kernel: [  268.134122] usb 2-1-port1: cannot disable (err = -110)
> Fri Dec 20 23:04:41 2024 kern.err kernel: [  273.134129] hub 2-1:1.0: hub_port_status failed (err = -110)
> Fri Dec 20 23:04:42 2024 kern.err kernel: [  274.134118] usb 2-1-port1: cannot reset (err = -110)
> Fri Dec 20 23:04:43 2024 kern.err kernel: [  275.134121] usb 2-1-port1: cannot reset (err = -110)
> Fri Dec 20 23:04:44 2024 kern.err kernel: [  276.134072] usb 2-1-port1: cannot reset (err = -110)
> Fri Dec 20 23:04:45 2024 kern.err kernel: [  277.134064] usb 2-1-port1: cannot reset (err = -110)
> Fri Dec 20 23:04:46 2024 kern.err kernel: [  278.134131] usb 2-1-port1: cannot reset (err = -110)
> Fri Dec 20 23:04:46 2024 kern.err kernel: [  278.134157] usb 2-1-port1: Cannot enable. Maybe the USB cable is bad?
> Fri Dec 20 23:04:47 2024 kern.err kernel: [  279.134064] usb 2-1-port1: cannot disable (err = -110)
> Fri Dec 20 23:04:52 2024 kern.err kernel: [  284.134016] hub 2-1:1.0: hub_port_status failed (err = -110)
> Fri Dec 20 23:04:53 2024 kern.err kernel: [  285.134008] usb 2-1-port1: cannot reset (err = -110)
> Fri Dec 20 23:04:54 2024 kern.err kernel: [  286.134009] usb 2-1-port1: cannot reset (err = -110)
> Fri Dec 20 23:04:55 2024 kern.err kernel: [  287.133998] usb 2-1-port1: cannot reset (err = -110)
> Fri Dec 20 23:04:56 2024 kern.err kernel: [  288.133992] usb 2-1-port1: cannot reset (err = -110)
> Fri Dec 20 23:04:57 2024 kern.err kernel: [  289.134012] usb 2-1-port1: cannot reset (err = -110)
> Fri Dec 20 23:04:57 2024 kern.err kernel: [  289.134042] usb 2-1-port1: Cannot enable. Maybe the USB cable is bad?
> Fri Dec 20 23:04:58 2024 kern.err kernel: [  290.133978] usb 2-1-port1: cannot disable (err = -110)
> Fri Dec 20 23:04:59 2024 kern.err kernel: [  291.133987] usb 2-1-port1: cannot disable (err = -110)
> Fri Dec 20 23:05:04 2024 kern.err kernel: [  296.133952] hub 2-1:1.0: hub_port_status failed (err = -110)
> Fri Dec 20 23:12:11 2024 daemon.info procd: Instance gl_nas_sys::gl_nas_sys pid 11612 not stopped on SIGTERM, sending SIGKILL instead
> Fri Dec 20 23:13:49 2024 kern.err kernel: [  821.627892] ubi0 error: ubi_open_volume: cannot open device 0, volume 2, error -16
> Fri Dec 20 23:13:49 2024 kern.err kernel: [  821.627938] ubi0 error: ubi_open_volume: cannot open device 0, volume 2, error -16
Sorry for the late reply, as we are trying to reproduce this issue,
Please upgrading the latest beta firmware for the AXT1800 to test if it works.
https://dl.gl-inet.com/router/axt1800/beta
I honestly don't know the answer but I wanted to ask you a quick question.
Have you tried using an FTP software like FileZilla or Commander One?
How fast are the write speeds you getting to SSD over wifi when its attached to the router? Thanks.
I don't see anything definitive in that log, but its an odd chain of failures all related to the USB hub/connection. As a guess, that SSD may be drawing a bit more power at peak (i.e. when its writing) than the Slate AX can provide via USB.
If you've got a powered USB hub, give that a try. Note: it'll probably be best to reformat the drive on a laptop/desktop first as the allocation table may be messed-up.
