Ssl-vpn fortigate
Hi there, how can I configure any Glinet device to connect to a SSL-VPN server (Fortigate 30e)?
I use the FortiClient on Windows to connect, but is it possible to configure the SSL-VPN client on my travel router?
Hi JFBF1995!
You could try to install the openfortivpn packages in the software menu of the advanced router settings.
kind regards
Ok, installed, but how do I configure it? I’m new to openwrt and Glinet softwares
It is not really supported by OpenWrt so it will be pain to configure. See GitHub - adrienverge/openfortivpn: Client for PPP+TLS VPN tunnel services
I guess you might even need to create an own script so the VPN will start after reboot.
