Starlink + slate 1800 ax
Since last update the starlink app can’t connect local.
Only cloud is usable.
I need the local connection to get to some settings in the starlink app.
This is happening since the last update..
Are there more users that have the same problem?
Is there a setting i should change?
Grtz,
Rob
Is this issue occurring after upgrading to v4.7.0 firmware? And it works fine in v4.6.8?
Is the Bypass mode enabled on Starlink?
Hi Bruce,
Since last update this problem occured.
Before no problems..
Grtz,
Rob
Maybe we would like to confirm first if the Bypass mode enabled on Starlink.
If no luck, please try to downgrade the firmware to v4.6.8:
https://dl.gl-inet.com/router/axt1800/stable
Hi Bruce,
Downgraded to the former firmware, and now it works again.
No bypass possibility with starlink standard actuated(no built in router)
Grtz,
Rob
What is the network topology? please shows as an image.
Does the standard Starlink have no built-in router?
What settings are available when the Statlink APP is connected local?
